Results 1 to 5 of 5
Thread: Life expectancy of copper and black iron pipe
    DIY Member luc's Avatar
    Apr 2007
    Quebec, Canada
    Default Life expectancy of copper and black iron pipe
    Hello everyone,
    We are doing some renovation on our hydonic heating system which is over 50 years old. The black iron pipe is in good condition. Just want to know if it is better to use copper pipe or black iron for our renovation. Which will have a longer life expectancy?
    Thanks,
    Luc
    Dec 2009
    northfork, california
    Your black iron pipe is DUCTILE IRON pipe. Very good material. Gas line is junk. Do not make that mix up.
    http://www.dipra.org/
    http://www.vikinggroupinc.com/en/products/489/600
    Apr 2007
    Quebec, Canada
    Thanks ballvalve for replying.
    So it would be better to continue with the ductile iron pipe for our renovations rather then copper!!
    Luc
    If you maintain the heating system so there are no leaks and you don't have to add water regularly, the iron pipe can last a very long time. It has problems when you introduce air into the system (by adding water - there is some gas disolved in the water). Copper works, too, but is more expensive, but easier to cut and work with. The iron pipe reacts with the O2 in side along with the moisture to rust out from inside. No O2, no rust.
    Apr 2007
    Quebec, Canada
    Thanks jadnashua and ballvalve for the replies. It answers my questions.
  1. Life expectancy of a bladder tank
    By Bob999 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-27-2009, 12:01 PM
  2. Pipe Life Expectancy
    By rckowal in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2009, 05:43 PM
  3. Life expectancy of fiberglass tub surrounds.
    By MaryAnnKacz in forum Shower & bathtub Forum & Blog
    Last Post: 03-08-2006, 03:48 PM
  4. Black Iron & Copper Together
    By emerrill1@comcast.net in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2005, 10:41 AM
  5. life expectancy
    By sdan in forum Toilet Forum discussions
    Last Post: 09-27-2005, 05:37 PM
