Results 1 to 10 of 10
Thread: DWV Advice Please...Bathroom + Laundry Room
    DIY Junior Member rughead92's Avatar
    Jun 2011
    new jersey
    Default DWV Advice Please...Bathroom + Laundry Room
    I am putting in a half bath room in part of my old laundry room. There is a laundry sink and washing machine drain stack existing now. The sink drain is attached to a vertical 1 1/2 inch vent up through the roof. The laundry drain stack is tied into that vent/drain.
    I need to move the laundry drain over 90 degrees to the new wall I framed and add a toilet drain. The horizontal drain lines in the basement in this area are 2 inch - so I know I need to change them out to 3 inch.
    I would appreciate any advice on setting up the drains and vents the best way. Thanks!
Size:  46.6 KBName:  house 011b.jpg
Size:  53.4 KBName:  house 006b.JPG
Size:  97.1 KBName:  house 009a.jpg
Size:  44.0 KBName:  house 007b.JPG
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    Only hard part I see is how are you going to get a new vent for the toilet up the wall.
    The existing vent for the lav is 1-1/2 inch and you need at least 2 inch vent.
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    Plumber jimbo's Avatar
    Is that a toilet flange on the floor? Was that existing? Maybe it is already tied in//
    Jun 2011
    new jersey
    I just cut the hole for the toilet flange...haven't tied it into the drians yet.
    And I thought I was ok with the 1 1/2 vent because the DWV in the basement is only 3 inch.
    Thanks.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Vent can be 1/2 the size of pipe you are venting.3" pipe 1 1/2" vent.If you want to go larger vent that is ok.
    Nov 2010
    Maine
    Under IPC and UPC toilets can be vented with 1 1/2 and the distance from closet to vent is unlimited
    Jun 2011
    new jersey
    Can you advise on the laundry drain. Can I am extend the laundry drain around the 90 degree turn (new wall) and leave it attached to the existing drain stack. Its less than 5 feet away from the vent. Will the the 90 degree turn soon after the trap will cause a problem? Would I have to tie in a new vent after the 90 degree turn (extending up 4 feet, then horizontal over to the existing stack?)
    Nov 2010
    Maine
    The 90 should be fine. Be sure you are within vent to trap distance though.
    Expert Plumber plumber2011's Avatar
    Jun 2011
    Boston, Massachusetts
    Hi Rughead,
    That 90 is fine as long as it is a LONG SWEEP 90, but tell us, is wet venting allowed in your area? How are you planning to run the piping for this new toilet...what vents the toilet here and how are you connecting everything? I don't think any code will allow a washing machine to wet vent a toilet, so you probably can't use the 2" (reduces to 1.5") feeding the sink/washing machine as a toilet wet vent, OK? Answer my questions...see what we all think here.
    You'll need a 3" cleanout on the new 3" drain at the change of direction where you connect into the existing 3" drain line and another 3" cleanout at the end of the run near the toilet, too, OK?
    Back to you...
    By the time you finish the job, EVERYTHING you have now will probably be removed and revised. UPC REQUIRES a 2" vent for a toilet. we would have to be there, and it would cost you, to "set up the drains and vents properly". Installing them "properly" is our job and what we get paid to do.
  1. new bathroom and laundry room being done by contractor
    By janetcal in forum Shower & bathtub Forum & Blog
    Last Post: 09-02-2013, 10:27 AM
  2. bad smell from laundry room and water heater tank room
    By ttaiko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2011, 01:07 PM
  3. Need help/advice planning new plumbing for a laundry room
    By benze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2010, 07:59 AM
  4. DWV Layout Critique........Bathroom & Laundry Room.
    By spetrucco in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-13-2010, 02:59 PM
  5. Second Floor Laundry Room Help
    By MikeG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2008, 04:46 AM
