Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Orange Mold in a Schluter Systems Kerdi Shower - Linear Trench Drain
    Jul 2009
    North Vancouver, BC
    Default Orange Mold in a Schluter Systems Kerdi Shower - Linear Trench Drain
    post(s) removed by John Whipple
    Jul 2009
    North Vancouver, BC
    Default What causes "Orange Mold" in a shower?
    There are a couple of molds that are orange and they'll form on any surface under the right conditions...I seriously doubt the material leaches color. Once they get established, it is tough to get rid of them.
    Jul 2009
    North Vancouver, BC
    Default Organic Soaps or Mold
    At the school I went to on Shluter stuff, they had a cardboard box covered with Kerdi and thinset used as a drink cooler. The water never was anything but clear, and the color of the membrane had not changed over the months that box had been in use. they had to replace them periodically because of flex...the box became more of a bowl than a square box...not because it got wet, but because of the weight of the water and drinks it held over time and the constan flexing.
    Feb 2011
    NW Ontario, Canada
    I'm starting to see some orange spots on the grout on my KERDI shower but I think it is iron staining. I plan to hit it with some Super Iron Out soon. I need to get more aeration before the precip tank of my iron filter to combat the iron.
    Plumber jimbo's Avatar
    I am familiar with a pink mold in showers. My initial take on orange is "is it rust??". But the one and only solution to mold is drainage and VENTILATION!
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Iron bacteria will usually cause yellow, orange, red, or brown stains. It can also produce a slime.
    Jul 2009
    North Vancouver, BC
    Default Iron Content in Marble and Orange Mold.
    Apr 2011
    NC
    I found this on a site about counter tops.......One curious fact that sometimes results in rusty stains is that Carrera marble and other white marbles contain iron deposits. If these are consistently exposed to water long enough to oxidize the iron, then the rusty water is carried to the surface and can stain.
    This is much more common on floors, where a flood or leak could saturate the marble or trap water under the tiles providing enough moisture to oxidize the iron deposits within.
    Jul 2009
    North Vancouver, BC
    Dec 2007
    It is a bacteria, Serratia marcescens often pink or, orange and a pain in the butt to get rid of.
    http://en.wikipedia.org/wiki/Serratia_marcescens
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    OT, but a chemical test ?
    I have cleaning fluids that when they react with Iron...the cleaning fluid turns purple.
    urinating = makes this bacteria grow faster.
    I think. Have a study done to prove it. Or collect anecdotal evidence.
    Interesting about the iron test and purple.
    Jun 2006
    Actually the chemical is not a iron test.....per say, but when in use, when it hits iron, it reacts to it....and then turns from green to purple.
    I briefly skimmed the thread but I'm going to assume there exists some sort of iron test out there to confirm his suspicions, hopefully without causing more staining.
    I love Carrerra Marble in aot of things. I would never want it myself though. Too soft, too much maintenance, etc..
  1. Schluter's Line Drain - A closer look at the new linear shower drain from Schluter
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 07-15-2011, 07:47 AM
  2. Trench drain in shower using Kurdi
    By fredonparkln in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2011, 04:29 PM
  3. Replies: 4
    Last Post: 06-08-2011, 09:01 AM
  4. FreeStyle Linear Drain Installation & shower pan prep, etc.
    By Dee in SC in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2011, 04:11 PM
  5. Schluter-Kerdi shower install needed
    By cclearly in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2008, 01:06 PM
