Thread: pin holes in copper pipe
    DIY Junior Member Dennis Anthony's Avatar
    Jun 2011
    Kentucky
    Angry pin holes in copper pipe
    Hey everyone, new to the forum. I was wondering if anyone else has had problems of copper pipe corrusion a little while after installing a gas fired tankless water heater. About 6 years after installation I started having problems within 12 feet of the heater. Two different area,s. So far I,ve talked to three people with the same thing all with tankless heaters all on hot water lines close to the heater. There will be a little spot of green corrusion then a pin hole will develop. I appreciate any help I can get. Thanks Dennis
    Feb 2011
    NW Ontario, Canada
    Did the installation of the tankless change the electrical continuity of the the copper piping? What I mean is there some sort of electrical isolation now?
    Some theories of pinhole leaks suggest galvanic corrosion. Tank heaters have sacrificial anodes.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Heat accelerates corrosion. I would do a complete water analysis.
  1. "Notching" studs vs. holes in studs for copper pipe?
    By ironspider in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2013, 08:02 AM
  2. Pin Holes in Buried Copper
    By theestimator1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2008, 10:28 PM
  3. Pin holes in copper pipes
    By TampaJim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-01-2007, 06:36 AM
  4. plugging overflow holes in drain pipe
    By Scot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2007, 02:33 PM
  5. discovered 2 holes in the 3" copper vent
    By rehabclone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2005, 03:06 PM
