Results 1 to 7 of 7
Thread: Replacing door latch mechanism on sliding door
    DIY Junior Member julesy's Avatar
    Dec 2010
    ca
    Default Replacing door latch mechanism on sliding door
    Hi,
    I am trying to replace the lock on this sliding door. However, I cannot see anyway to get the existing lock out. I have had the door off its tracks and looked at the top and bottom, but am stumped as to how to remove and replace this lock.
    Is it possible that some doors are designed not to have the lock replaced? I find that hard to believe. What could I be missing?
Size:  19.3 KBName:  IMG_8722small.jpg
    Plumber jimbo's Avatar
    First you remove the handles. There should be some screws on the inside handle
    You may have to remove that section of the door frame and work on the lock from the inside.
    Dec 2010
    ca
    Thanks for the suggestions. Yes, I removed the handles as shown in one of the pics. After seeing no other way to do this, I looked at opening up the door frame, but it seems to have plastic "welded" type joints and I could see no way to get the lock out. I'm stumped.
    A manufacturer would need to have extreme, and misplaced, confidence in the longevity of his latch to make one which could not be replaced. Unfortunately, without seeing it we may not be able to help you, since each manufacturer would have his own method of installing the latch.
    DIY Member Agu's Avatar
    May 2009
    Tampa, FL
    I see two screws on the end of the door that haven't been removed . I also see grooves above the top screw and below the bottom screw. Seems to me you could remove both screws and the lock mechanism will pull forward and out of the door.
    Might just be that simple .....
    Dec 2010
    ca
    Thanks. I figure out how to do it in the end. It was as Agu suggested, you simply remove the two screws on the end of the door and the lock can squeeze out. As the lock is longer than the hole, I had just assumed, there must be a different way to get it out. Thanks all.
  1. Installing Kohler sliding glass shower door:
    By oldberkeley in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2010, 10:12 AM
  2. Garage door in RO less than door width?
    By jrfiero in forum Remodel Forum & Blog
    Last Post: 06-19-2009, 05:36 PM
  3. Sliding glass door giving me fits
    By inexplorata in forum Remodel Forum & Blog
    Last Post: 10-30-2008, 08:28 AM
  4. sliding shower door
    By willl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2008, 01:23 PM
  5. Sliding glass door removal
    By Wardsweb in forum Remodel Forum & Blog
    Last Post: 03-24-2008, 09:31 AM
