The best thing to do with the heads you want to elimenate is dig down to where each head is connected to the white pvc pipe, unscrew the fitting and replace it with a 1/2 inch threaded plug being sure to use teflon tape to seal the threads. For the raised beds you can convert the fittings to move the heads to those boxes or change them to drip lines or micro-sprays according to what you want to plant.
