Thread: Short Duct Run to Bathroom Has Little to No Air Flow
    DIY Junior Member kailor's Avatar
    Dec 2010
    Huntsville, Alabama
    Default Short Duct Run to Bathroom Has Little to No Air Flow
    I have a 3' straight duct run from the main trunk in a mobile home to a bathroom. It just does not have any air moving throuh it! How can I vastly improve the air flow into the bathroom?
    Thanks.
    You may need a deflector in the main to direct air there. Or, put a booster fan in the duct.
    DIY Junior Member TheycallMeDave's Avatar
    Jul 2011
    Northern Florida
    Quote Originally Posted by kailor View Post
    Thanks.
    First, id make sure that tiny diameter duct isnt partially restricted with debris inside it (or partially crushed) ... then id run a larger diameter duct providing you have access to the main trunk duct where the branch duct is attached. You may want to run something fairly flexible thru the duct opening back to the main duct to make sure it is fully open without restriction.
  1. Reconnecting bathroom fan exhuast duct
    By DanGles11 in forum Remodel Forum & Blog
    Last Post: 04-09-2011, 02:38 PM
  2. slow cold water flow in bathroom
    By kimmoore in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2009, 10:59 AM
  3. Pump is short cycling.....Very short!!
    By crittercatcher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-29-2009, 09:26 AM
  4. Maximum length of duct for bathroom fan
    By Douche in forum Shower & bathtub Forum & Blog
    Last Post: 04-13-2006, 07:12 AM
  5. Low water flow in 2nd bathroom
    By gotpeter in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2005, 10:43 AM
