No cold water coming from my single handle Pfister lavatory faucet
anglii
Alberta Canada
We've had this Pfister T42-YP0 single handle faucet for about a year and it worked just fine until we added two compression fitting shut-off valves to the water line. Now the cold water just trickles (hot has less pressure than before but acceptable).
thumb2.php
I accidentally got some drywall mud/depris into the valves before the braided hoses were attached. Can this be the problem or what else can it be? Any help would be appreciated.
Are you sure you did not "kink" the supply lines between the valve and the faucet? "Drywall dust" would have been flushed out IMMEDIATELY when the water was turned on. If the aerator was plugged, you would get the same amount of water from both sides. Were these the type of valve which you screwed on to the original valves between the valve and supply line? If so, THAT may be where the obstruction is. Ihave a fairly low opinion of that type of valve.
anglii
Alberta Canada
Thanks hj for the super fast reply!
The valves are sharkbites. Was told that all the plumbers where using them now but from what I'm gathering they aren't a permanent solution and may eventually leak. Do these valves have known issues that could cause the cold water to trickle? Should they be replaced?
"Real plumbers" do NOT use them, for a few reasons, cost being one of them, but they should not cause your symtoms, assuming you did NOT crush the "stabilizer sleeve" which is used with plastic lines.
anglii
Alberta Canada
hj help!
So I disconnected the cold water supply line from the faucet to the shut-off valve and gauging from the water dripping down my face after I opened the shark valve, the valve works just fine. I did notice a chunk of debris in the line and removed it but now I'm worried that more debris has been pushed further along the line where I can't reach it. Any suggestions?
I had to get a neighborhood kid to undo the line for me because hubby isn't here for another week and I didn't have the strength, so don't want to reconnect until all options have been explored.
I took an air hose and blew into the faucet opening (where the water normally comes out) but that didn't work at all. The air just blew back out of the same opening (path of least resistance) :(
