Thread: Drake makes noise after flush/fill is done
    DIY Junior Member transcend's Avatar
    Jun 2011
    oakland, ca
    Default Drake makes noise after flush/fill is done
    It's like when you turn a car off and the engine keeps running for a bit. It's an airy Ch-Ch-Ch-Ch sound, and lasts for about 15-20 seconds after the tank is refilled. It's coming from the green part inside the tank. In other parts of the house, though, it sounds much louder, like a clunking valve sound. Any ideas? TIA.
    Jun 2011
    oakland, ca
    Default More Info
    I looked in the tank last night and noticed this is an Eco-Drake, not a Drake. Don't know if that makes any difference. Also, the bathroom floor is not even. Not a few wobbles, but the whole floor tilts off to one side.
    If the flapper is leaking, then the tank will continue to refill over and over again. Check to make sure the flapper isn't leaking.
    If the flapper is good, and the water in the tank is going over the top of the overflow tube, then the fill valve needs cleaning or repair.
    www.terrylove.com/korky
  1. Faucet makes odd humming noise
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2011, 02:24 PM
  2. Furnace Makes Noise on Startup
    By alexjag33 in forum HVAC Heating & Cooling
    Last Post: 01-09-2009, 09:04 AM
  3. reverse osmosis makes noise
    By vegashomes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2008, 04:07 PM
  4. House makes burping noise
    By Eric E in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2006, 10:15 AM
  5. Toto Drake Flush/Fill Pause
    By Jerome in forum Toilet Forum discussions
    Last Post: 11-23-2005, 06:49 PM
