Results 1 to 2 of 2
Thread: new toilet. tank bolts started leaking?
    DIY Junior Member 42flathead's Avatar
    Feb 2009
    Maine
    Default new toilet. tank bolts started leaking?
    Noticed water leaking from toilet tank bolts.Installed toilet last fall and had no problem at all until now? I have the metal washer on top of the rubber washer inside tank. Should I remove the metal washer from the top of the rubber washer and just have the head of the bolt in contact with the rubber washer for a better seal?
    quote; I have the metal washer on top of the rubber washer inside tank.
    In that case it has ALWAYS leaked, you just noticed it now. Yes, remove the metal washer and put it UNDER the tank.
  1. Leaking tank bolts
    By pjsammy in forum Toilet Forum discussions
    Last Post: 10-28-2009, 08:42 AM
  2. novice question about toilet tank bolts/hardware
    By cjs1996 in forum Toilet Forum discussions
    Last Post: 12-25-2006, 10:04 AM
  3. Toilet tank has no bolts ?
    By cdm in forum Toilet Forum discussions
    Last Post: 06-10-2006, 03:09 PM
  4. well pump to pressure tank fitting warped and started leaking
    By fumplet in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-12-2006, 10:41 AM
  5. Correct use of washers on toilet tank bolts
    By SteveW in forum Toilet Forum discussions
    Last Post: 04-10-2005, 02:50 PM
