Results 1 to 5 of 5
Thread: help needed quickly, re: ac fuse
    DIY Junior Member Laura Albertini's Avatar
    Jun 2011
    Wilmington, NC
    Default help needed quickly, re: ac fuse
    I have a issue with my ac unit 's fuse. How can I tell if it is burned and need a new one.. if so, where would I go and how much are they? The fuse if attached to a t shaped holder, and one side looks like it is burnt, help please!! It is hot in here!
    Jan 2008
    We don't know what you are looking at, as most central air units do not have fuses.
    If you posted a couple pictures along with the make and model information, it might be helpful.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    The fuse is most likly the service disconect which is required for servicing the unit.
    Most likly you have a bussman 30 Amp fuse, but could be more I've seen upto 60 amp fuses but that is alot of power.
    Take the Tee part fuse holder pulls out as part of the service disconnect, just take that to Home Depot and they should be able to hook you up with replacement fuses.
    I think that they are about $4 each.
    Michael
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    If the holder looks burnt, it may need to be replaced. Excessive heat can make the springs that hold the fuses and make the connection weak, and make a poor connection, causing more heat and potential failure. If it gets intermittent, it could burn out the compressor as well.
    Default fuse
    The only way to really tell if a fuse is good or not is with a continuity tester.
  1. hot water runs out QUICKLY
    By ewillyb in forum Water Heater Forum, Tanks
    Last Post: 11-22-2009, 06:59 AM
  2. Jet Pump Cycling Quickly
    By jkevin in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-27-2009, 02:45 PM
  3. pump shuts off too quickly - new system
    By type@uwm.edu in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-31-2008, 07:53 PM
  4. Pressure switch cycles quickly
    By daul10 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-15-2006, 06:24 PM
  5. Heating a joint quickly
    By ToolsRMe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-17-2006, 07:52 AM
