ABS (solvent (aka "glue") can only be used to join ABS pipe to ABS fittings. (The same rule applies to PVC solvent) Your drain fitting should have directions for installation enclosed. The shower stall rests all of its weight on the floor, usually with mortar spotted beneath to prevent sagging or flexing under heavy weight, and is nailed or screwed to the studs at the top and down the edges to keep it from shifting. The drain does not support any weight. The pipe needs to be cut to the correct height as will be indicated in the drain fitting instructions. Follow the instructions carefully and you shouldn't have a problem.
Hello everyone. I'm installing a no caulk shower drain for the first time and I'm looking for instructions on how to do it correctly. The one that I am replacing is leaking somewhere and is causing serious damage to the room downstairs. I know that I already have to replace the damaged drywall below so gaining access underneath is not an issue. Also, when looking at the drain line it doesn't seem to be supported well enough around the bottom of the stall (one-piece fiberglass) and right now it seems to me that the weight of someone using it in the future will cause this to happen again.
Using crossed screwdrivers also allows the pipe to be a bit higher into the drain, making it unlikely that the pipe top could ever get below the top of the black gasket, even with flexing of base/floor.
