Results 1 to 6 of 6
Thread: water backup in sewage line
    DIY Junior Member mongoose's Avatar
    Jun 2011
    nc
    Default water backup in sewage line
    i have sewage water backing up and coming out of the bottom of the floor on the downstairs toilet as this is the lowest point in the house... right outside the house 5 feet from this toilet a pvc wye with a cap it... when i unscrew the cap, water comes out as its about as high as the floor... is this more than likely a clogged main in my front yard(i have a tree) or could it be something more serious...its 3am now and just finished cleaning up the water from my last load of laundry and the pipe in the yard is full...is auger the way to go here...
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Yep, more than likely its roots from the tree. Auger then I always recomend having a camera inspection done after to see where and what the problem was.
    Dec 2007
    Yep the line needs to be cleaned...
    As for what the problem is you never really can tell until the snake is in the pipe.
    Then it's an educated guess based on the drain cleaner's experience and skills.
    The camera inspection is a good way to know for sure...
    Auger it, but do NOT waste hundreds of dollars on a camera inspection, unless the plumber has a problem unplugging the line, OR it happens again within a few months. I MAY have videoed a dozen sewers in my lifetime, but ALL of them had serious problems and I had to know what or where it was.
    Dec 2007
    As technology has gotten cheaper and more abundant there are many companies that now camera almost every main line they clean.
    Of course they are hoping they see something and can sell a repair....
    One thing to avoid is trying to clear this with chemicals. Not only will they not clear the clog, they can create a hazard for the plumber you eventually will have to call to auger the line.
  1. Backup in waste line
    By ianrtech in forum Drain Cleaning
    Last Post: 01-09-2012, 04:57 PM
  2. Is sewage backup related to my new Toto Eco-Ultramax?
    By espeedy123 in forum Toilet Forum discussions
    Last Post: 08-27-2007, 03:58 PM
  3. Sewage/Plumbing backup
    By cmc in forum Plumbing Forum Discussion & Blog
    Last Post: 07-23-2007, 06:18 PM
  4. Sewage pump backup
    By Guest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2006, 03:09 PM
  5. Main line backup after replacing toilet.
    By AC in forum Toilet Forum discussions
    Last Post: 07-08-2005, 09:09 AM
