Results 1 to 5 of 5
Thread: Sears Power Miser 12- Similar Symptoms as the stickied Whirlpool Flamelock ?
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Sears Power Miser 12- Similar Symptoms as the stickied Whirlpool Flamelock ?
    Hi All -
    I have a Sears Power Miser 12, circa. Late 2006 model.
    It just started doing this where the pilot light goes out.
    I light the pilot, then turn up the temp. It looks like it brings the water to temp and then the pilot goes out . So for the past day, I've been doing the same old routine pilot-boil water and then in between errands and stuff, follow the same routine.
    In search of a fix, I came across this thread.
    On the famous thread sticked for the whirlpool, would the fix possibly be applicable as per above ?
    Boiler was replaced on a whim due to leaking tank, and go figure....their xtended warranty is terrible. The earliest appt I could get from them is 2 weeks out.
    Don't laugh but my previous copper boiler was like 30+ years old .
    Dec 2007
    Yep...
    It's the same damn junk...
    Jun 2006
    Been looking at Bradfords online.
    When looking at specs, is the only big difference the venting systems....
    There seems to be 3-4 variants in the natural gas lines - 50 gal
    Dec 2007
    Which ones are you looking at?
    Jun 2006
    Defender Extra Recovery unit.
    Unless you can recommend a 60 gallon with a 60" H footprint max (vent stack is currently a smigen higher )....
  1. Kenmore Power Miser 12 gas WH won't reach rated temperatures
    By Rock51 in forum Water Heater Forum, Tanks
    Last Post: 02-27-2010, 02:15 PM
  2. Video of my burner flame in Kenmore Power Miser 9
    By vtxdude in forum Water Heater Forum, Tanks
    Last Post: 01-05-2010, 01:41 PM
  3. Power Miser 12 repair
    By aynsdad in forum Water Heater Forum, Tanks
    Last Post: 11-14-2009, 03:44 PM
  4. Whirlpool flamelock water heaters
    By tommyo in forum Water Heater Forum, Tanks
    Last Post: 10-31-2009, 08:34 PM
  5. Similar Odd Power Outage problem too....
    By rundawg325 in forum Electrical Forum discussion & Blog
    Last Post: 10-08-2008, 04:11 PM
