Results 1 to 4 of 4
Thread: changing house supply connection
Hybrid View
    DIY Junior Member jasontf's Avatar
    Jun 2011
    Texas
    Default changing house supply connection
    I need to change my main house shutoff from a gate valve to a ball valve. I have 3/4" soft copper coming in and 1" galvanized pipe inside. What is the best way to make this connection?
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    can you send a picture not enough info.
    Jun 2011
    Texas
    I can't get a picture now. It's an old house. I have 3/4" soft copper to a compression fitting, then a threaded gate valve (1"), then a galvanized union (1"), then a short galvanized nipple (1"), and a galvanized tee to go into the house (1") and into a hose bib(1/2").
    The obvious answer would be to use a 1" ball valve and spend a couple of hours to adjust the galvanized piping as necessary, possibly making multiple trips to the Ace Hardware store, to make it fit. Or call a plumber who can do the whole thing in a matter of a half hour or so.
  1. Water Supply Connection for House and Irrigation
    By jasontf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2011, 10:00 AM
  2. Dishwasher supply line connection/water inlet valve
    By GregN31 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2011, 08:21 AM
  3. changing supply and return lines
    By williambonetto in forum Boiler Forum
    Last Post: 07-04-2010, 08:18 PM
  4. leaking Dishwasher supply connection at 90 angle pipe threads
    By AKRBT in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2008, 08:46 PM
  5. supply valve corrosion at compression connection
    By Ry in forum Toilet Forum discussions
    Last Post: 01-27-2008, 05:58 PM
