Results 1 to 6 of 6
Thread: Kenmore Softener Problems
    DIY Junior Member btb079's Avatar
    Jun 2011
    Wisconsin
    Question Kenmore Softener Problems
    I have a Kenmore UltraSoft 250. It was in the house when we moved in 5 years ago. It has never really seemed to soften the water. The resin tank was replaced in 2007 because it cracked and flooded the basement, but that is a different story.
    Like I said the water softener has never really seemed to work right. It goes through salt, but the water doesn't seem soften whether it's set to the lowest setting or the highest. I've pulled out and cleaned the nozzle/venturi several times, but it doesn't make a difference. I've also gone through the troubleshooting steps on Kenmore's site. Recently, we've been getting a slight sulfur smell from the softened water, but last night a put some bleach in the brine and ran a regeneration and it seems to have gone away.
    Can anyone give me some other ideas to try to fix this? I'd like to try to fix this myself before buying another one.
    Bill
    Dec 2009
    Alaska
    Start with a test of the water before the system and after the system.
    There might be a blow by leak, untreated water getting to the treated side.
    One point could the the bypass handle not seated all the way to service, the other could be that the disc seal is broken and letting water cross within the valve or that the o ring on the distributor is missing ....
    Mar 2011
    Houston, TX
    Hello Bill, Welcome to Terry's Forums,
    I would replace the unit, Then you know your starting point.
    You can get a test kit and determine the hardness level that you have , then go from there.
    Parts are available for the Kenmore, But a replacement would be best. Sears does back their product.
    Have a Great Day.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Jun 2011
    Wisconsin
    Thanks for the replies. Where would one get a water test kit?
    Dec 2009
    Alaska
    Box stores might, local hardware store might.
    Mar 2011
    Houston, TX
    Quote Originally Posted by btb079 View Post
    Ace hardware or;
    http://www.amazon.com/Water-Hardness.../dp/B004R6VXLI
    Enjoy your day.
    DonL
  1. Kenmore water softener
    By dt196 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-19-2011, 12:32 AM
  2. Kenmore water softener
    By dt196 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-26-2009, 04:29 AM
  3. Kenmore Water Softener help?
    By a12548 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-04-2008, 01:10 PM
  4. Kenmore softener
    By mfox in forum Plumbing Forum Discussion & Blog
    Last Post: 10-28-2007, 11:04 AM
  5. Kenmore Water Softener
    By DarylF08 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-05-2007, 09:21 AM
