Results 1 to 1 of 1
Thread: Info We Need to Better Answer Your Questions
    Moderator valveman's Avatar
    Mar 2006
    Default Info We Need to Better Answer Your Questions
    Please use this form to supply as much information as you can about your well or pump system before asking for advice. This will better help us answer your questions.
    Copy/Paste the following form to your post. Answer as many of the questions as you can. Don’t worry if you only know a thing or two about your pump and well. We will help you fill out as many as we can. A picture or two is always a great idea. We can fill out many of the blanks just by seeing a picture. You will have a detailed record of your pump and well information that you can save or print. This will greatly help us diagnose your problem, and be a great value to have as much information about your pump system as possible.
    Type of pump?
    Submersible________
    Two wire (no control)________
    Three wire (control box)______
    Wire Size_________ Wire Length________
    or
    Jet Pump (above ground)_________
    One or two pipes down the well____
    Size of Pump?
    Motor Horsepower?__________
    Pump Model #______________
    Date Pump Installed__________
    Pumping from?
    Cistern tank___________
    Pond, lake, river________
    Water Well____________
    Depth of well__________
    Depth to water_________
    Pump Setting__________
    Pipe Size_________"
    Drop Pipe Material
    PVC________
    Steel_______
    Poly________
    Well Recovery Rate_______gpm
    Well Casing Diameter_______”
    Rock Well__________ Sand Well__________ Other______________
    Date Well Drilled____________
    Well Casing Material
    PVC________ Steel_________ Other_________
    Pressure Tank?
    Bladder or diaphragm tank (one pipe to tank)__________
    Size or model of tank____________
    Air charge in top of tank, with pump off and water drained____________PSI
    (check with car tire gauge)
    or
    Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)_________
    Size of tank________________
    Pressure Switch Setting?
    On 30, off 50 ________
    On 40, off 60_________
    Other_______________
    Pump Control Method?
    Cycle Stop Valve model #_________
    Variable speed control #__________
    Pump Start Relay (sprinkler timer, no tank)__________
    Manually turned on and off____________
    Pump Protection
    Cycle Sensor_________
    Pumptec_____________
    Low pressure cutoff switch (lever on side)__________
    Filters or Softeners______________
    Before or after pressure tank_______
    Type of filter___________________
    Bypass available________________
    Water Used For?
    House Use_______ Number of baths_______ Number of People________
    High Flow Showers_______gpm?
    Plus/Or
    Irrigation with timers________
    Irrigation with hoses________
    Heat Pump______gpm?
    Problems Experienced
    No Water_________________
    Water only part time________
    Water at all times but weak_____
    Air in water_______________
    Pressure surging___________
    Water Hammer (noise)______
    Too Much pressure_________
    Other____________________
    Pump makes clicking or buzzing sounds________
    No Sounds______________
    Pressure gauge reading________psi
    Other____________________________________
    Do you have, and know how to use
    an Ampmeter and Voltmeter__________________
    Describe Problem__________________________.....
  1. Please answer these questions best you can
    By vtxdude in forum Water Heater Forum, Tanks
    Last Post: 12-30-2009, 07:00 AM
  2. Please Help Answer Some Toilet Questions!!
    By etoiletdog in forum Toilet Forum discussions
    Last Post: 05-20-2009, 08:12 AM
  3. I should know the answer but dont
    By perrycat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2007, 10:25 PM
  4. Answer buy a new one??
    By VAwife in forum Toilet Forum discussions
    Last Post: 05-07-2007, 10:09 AM
  5. Need an answer soon
    By psal2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-03-2005, 07:12 AM
