Results 16 to 30 of 37
Thread: Hot Tub Wiring
  1. #16
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Yes, PVC is acceptable. I would use EMT if it were my house. PVC can get droopy when it sits in the sun. Make sure it is supported to code.
  2. #17
    DIY Junior Member aopainter's Avatar
    May 2011
    Seattle
    it wont be in the sun. It'll be in my attic, and I'm going to get brackets to tie it down
  3. #18
    Mar 2011
    Houston, TX
    Use the correct Romex™ wire and skip the indoor conduit...Unless required in your town.
    P.S. And aopainter don't forget the cost to operate the unit, for the electric and chemicals to maintain it.
  4. #19
    Mar 2011
    Houston, TX
    Quote Originally Posted by ActionDave View Post
    SO should never be run in an attic. It is meant to be used where flexibility is needed not durability. It is never a substitute for permanent wiring.
    Thanks for pointing that out ActionDave,
    How flexible do you think a Type SO 6/3 wire would be.
    I guess you have never worked in the industrial plants, They use it for the big machines and run it in cable trays. And it is very durable, when installed and used in the proper environment.
    How many people have a cable tray in their attic ?
    Jim already said it all, Why don't you catch up.
    O , and have a great day.
    DonL
    P.S. Around here a outdoor Spa / Hot tub is not considered as a permanent fixture. That is why there is no requirement for a building permit. That may vary from area to area.
  5. #20
    May 2011
    Seattle
    What is the correct Romex™ wire?
    edit: I looked it up, and I still think it's going to be cheaper to get the cables and run them through PVC Conduit. I can get 6AWG red/blk for $63/100ft, and 8AWG wht for something like $40/100ft, and 12AWG grn/yllw for $30/100ft. Add that to the conduit that I should be able to get under $100, and I can probably run it all for under $300. For $100 ft of 6/3 romex, it runs around that same cost, and my electrician still wants THHW for the outside connection from the disconnect box, to run in EMT conduit.
  6. #21
    Mar 2011
    Houston, TX
    It should be on a ground fault interrupt.
    DonL
  7. #22
    Mar 2011
    Houston, TX
    Mixing conductor sizes and colors may be a problem, the ground wire can be smaller, but the other current conductors need to be the same size.
    I hope your project works well.
    Be careful playing with electricity...
    DonL
  8. #23
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    I would not change to a smaller size neutral. Some tubs also call for a ground the same size as the other conductors.
  9. #24
    Feb 2009
    Colorado
    Quote Originally Posted by aopainter View Post
    What size breaker are you tying the 6AWG to? I would guess either a fifty or forty amp breaker. That would mean you would need at least a 10AWG green.
    Jim Port correctly states that some manufactures, a lot actually, want a full size neutral and ground. Check your instructions.
  10. #25
    May 2011
    Seattle
    It's a 60 amp Disconnect panel
  11. #26
    Jun 2007
    North Carolina
    Don’t make this more than it has to be.
    Install #4 SE-R al. to the disconnect located on the outside wall and then flex and THW cu. conductors to the tub.
  12. #27
    Mar 2011
    Houston, TX
    I am glad you stopped by JW,
    I don't think that his friend needs to be thrown under the bus, he is trying to help out.
    And aopainter just wants help, not BS.
    Thank You...
  13. #28
    Feb 2009
    Colorado
    10AWG copper will work for an equipment ground up to sixty amp.
    This is another way to skin your cat and would most likely be more economical.
  14. #29
    May 2011
    Seattle
    I can't find this cable anywhere online to know what it looks like. I'm going down to the electrical wire store today, so I'll ask about that wire. I was able to get about 90ft of PVC conduit for $17, so i'm going to put that in the attic
  15. #30
    Mar 2011
    Houston, TX
    Save some conduit for exposed wire outside...
    What wire can you not find ?
  1. Spa Wiring
    By EdGear in forum Electrical Forum discussion & Blog
    Last Post: 05-19-2009, 11:19 PM
  2. Re wiring to to 12-2 /14-2
    By solutions in forum Electrical Forum discussion & Blog
    Last Post: 03-17-2008, 08:36 AM
  3. Wiring 101
    By MLTHAND in forum HVAC Heating & Cooling
    Last Post: 11-13-2007, 03:08 PM
  4. Three way wiring
    By Jed54 in forum Electrical Forum discussion & Blog
    Last Post: 08-04-2007, 03:01 PM
  5. Re-Wiring
    By laxnfish4 in forum Remodel Forum & Blog
    Last Post: 10-27-2006, 02:33 PM
