Thread: American Standard Deep Soak Drain
    DIY Junior Member Bob.W's Avatar
    May 2011
    Dallas, TX
    Default American Standard Deep Soak Drain
    Has anyone had any experience with the American Standard Deep Soak Bathtub Drain? It looks good (raises the water level by a couple of inches) but it's all plastic and doesn't look like it's worth it ($120+ retail). Is there anything else similar that may be made better?
    Bob
    Default drain
    It does not give much information, although it looks like it has to work by letting the overflow water in at the top of the plate, but it also says it was designed to work with their Evolution series of fixtures, so it might not fit generically on every tub. One problem might be if a tub has a rounded surface so it would not seal.
    One thing to be very careful of is that deep water in the tub means little room at the top for a 'wave'. Move a little, and you could have a big volume of water that now is on the floor outside of the tub. There's a reason they put the overflow where they do. Proceed with caution...
  1. Installing Hot Soak Tub - access panel questions
    By JuanSigned in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2011, 12:04 PM
  2. Help with american standard toilet!
    By AndyH in forum Toilet Forum discussions
    Last Post: 11-18-2009, 06:59 AM
  3. American Standard diverter
    By Guest in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2006, 01:20 PM
  4. american standard tub
    By deb8997 in forum Shower & bathtub Forum & Blog
    Last Post: 06-28-2005, 08:49 PM
  5. American Standard Vent Away
    By wkillpatri in forum Toilet Forum discussions
    Last Post: 01-24-2005, 08:13 AM
