Hello,
I have what i believe is a leak in a drop pipe. My well pump is cycling off for about 2 minutes and then on for about 2 minutes when no water is being used in the house. I shut off the water supply to the house to make sure there was no leak indoors and it still cycles on and off. I pulled the cap on my well and can hear water running inside but can't see any water leaking. I'm wondering if I can leave it in this condition until I can get it repaired or should I shut the power to the well off.
I'm also wondering if I could atempt to repair this myself. According to my records the well depth is 135' and the drop pipe length is 105'. Its a 4" well with a 3/4hp pump. I'm concerned about pulling it myself because I'm not sure if the leak in the pipe could be something that would come apart when pulling it and losing the pump down the well. There isn't any pull rope that I can see only the wiring to the pump.
Hope this makes sense and I appreciate any feedback.
