Results 1 to 8 of 8
Thread: What size (BTUs) air conditioners should I buy for my (sort of) open layout apartment
    DIY Junior Member mizrachi's Avatar
    Sep 2010
    NYC
    Default What size (BTUs) air conditioners should I buy for my (sort of) open layout apartment
    Our apt has an identical layout to this apartment, though a few feet bigger in all directions, and a pass-thru section between the kitchen and the living room. Our plan is to install 2 window ACs, one in the BR and one in the LR. The LR AC will need to compensate for the kitchen pass-thru and the BR AC will have to handle the bedroom door left open at all times (damn cats). So, how many BTUs for each? I'm thinking slightly larger for the LR but I'm unsure about numbers.
    Mar 2011
    Houston, TX
    Having the dimensions of the rooms, Including ceiling height would help you to get a better answer.
    Have a great day.
    DonL
    Sep 2010
    NYC
    Having the dimensions of the rooms would help you to get a better answer.
    Have a great day.
    DonL
    The dimensions and layout are linked in the body of the message.
    Mar 2011
    Houston, TX
    Quote Originally Posted by mizrachi View Post
    This may help;
    http://www.consumerreports.org/cro/a...ing-worksheet/
    Enjoy your day
    DonL
    Plumber jimbo's Avatar
    Window air conditioning is not an exact science, but for a starting point you can use a figure like 20 BTU per square foot. So a small 5,000 btu unit would handle the bedroom. For the total area of kitchen and l/r of about 400 sq ft, an 8000 btu would pencil out. Then you need to add for the heat of the kitchen..probably 2000 more btu, so put a 10,000 btu unit in the l/r. since the air will not readily circulate into the kitchen, you will find the l/r will be chilly, and the kitchen too warm. Ceiling fans or other circulators will help with that some.
    In the trades Dana's Avatar
    Jan 2009
    Without knowing the orientation, R/U values, air leakage rates, and shading factors it's impossible to put a number on it. Heat gain in an apartment is never a function of the square feet of living space, more a function of the amount of exterior surface area with direct sun, and air infiltration rates.
    In NYC the latent loads (humidity) will outstrip the sensible (temperature-only) loads several-fold. On a N facing apartment w/ air conditioned units both above & below you might do just fine with a dehumidifer rather than a window AC.
    If this is a unit that you own, not rent, a "ductless mini-split" system with continuously variable compressor & fan speed will be far more comfortable & cheaper to operate than any window shaker. Many can be set up to specifically control both humidity & temp.
    Mar 2011
    Houston, TX
    AMEN Dana.
    Have a Great day.
    DonL
    P.S the only problem with a dehumidifier, is that they add heat to the room, where they are located. Jimbo was correct about appliances adding heat, That has to be considered too.
    Jan 2009
    Agreed- rare is the unit that can make it on dehumidifer alone due to the space-heating effects. Keeping the duty cycle low enough to avoid raising the temp too much depends a lot on the actual air exchange rates. But 78F, 45% relative humidity is pretty comfy compared to 75F, 65% RH.
    Mini-splits have come a long way in the past dozen years, even for heating in NYC & southern New England climates. (They're even meeting/beating geothermal heat pump efficiencies in many heating apps.)
  1. Salt Free Conditioners vs. Tradiional Softeners?
    By Designie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-05-2011, 07:18 PM
  2. Calculating Propane Usage and BTUs for Tankless Hot Water System
    By Diavolicchio in forum Tankless Water Heater Forum
    Last Post: 12-21-2009, 02:04 PM
  3. Amusing.........sort of.
    By FloridaOrange in forum Computers and Stuff
    Last Post: 08-05-2009, 01:52 PM
  4. Landscaping question, sort of..
    By gibbie in forum Lawn Care/Landscaping
    Last Post: 03-27-2007, 01:49 PM
