Results 1 to 2 of 2
Thread: HVAC duct through a fire rated wall
    DIY Junior Member maurice53's Avatar
    May 2011
    Tucson, AZ
    Default HVAC duct through a fire rated wall
    I took a rear section of the garage and converted it to a laundry room with a wall now dividing it from the rest of the garage. This wall needs to be a fire rated wall. I am required to put HVAC register in this room. Can I put the duct through the wall and still maintain the fire rating?
    quote; I am required to put HVAC register in this room.
    Usually, ABSOLUTELY NOT permitted, because that could allow carbon monoxide from a car engine to enter and circulate through the house. Many people have gotten ill, or died, when a car was idling in the garage while the exhaust gases are circulating through the house, because someone wanted a "warm garage". But if you do insist, you have to jump through a lot of hoops to do it, because it would have to have a fire damper in it with a fusible link which activates it in the event of a fire. Your installation would have to be approved by your local fire inspector before AND after it is installed.
  1. Cost to duct small house for HVAC ??
    By ballvalve in forum HVAC Heating & Cooling
    Last Post: 12-06-2010, 12:12 PM
  2. HVAC 2nd Floor reversed intake duct ?
    By LB in forum HVAC Heating & Cooling
    Last Post: 06-02-2010, 09:08 AM
  3. Fire Rated Ceiling- Condo
    By KULTULZ in forum Remodel Forum & Blog
    Last Post: 10-16-2008, 05:58 PM
  4. Recessed Lighting And Fire Rated Ceiling
    By KULTULZ in forum Electrical Forum discussion & Blog
    Last Post: 06-24-2008, 12:17 PM
  5. Fire-rated pull-down stairs into attic above garage
    By Mikey in forum Remodel Forum & Blog
    Last Post: 04-30-2008, 12:23 PM
