Results 1 to 4 of 4
Thread: 15A outlets/switches on 20A circuit
    DIY Junior Member maurice53's Avatar
    May 2011
    Tucson, AZ
    Default 15A outlets/switches on 20A circuit
    I have outlets on a number of 20A circuits (12/2 wire)- dining area, kitchen counter, den, garage- that appear to be rated 15A. Is this okay? Do wall switches need to be rated according to the circuit amps?
    Jun 2007
    North Carolina
    This is code compliant
    If it was a single receptacle on a 20 amp circuit then it would be required to be rated at 20 amps but a duplex receptacle on a 20 amp circuit can be rated at 15 amps
    Mar 2011
    Houston, TX
    Quote Originally Posted by maurice53 View Post
    The wall switch needs to be rated above the load that they are switching, Not the Max circuit amps that the breaker can provide.
    Have a great day.
    DonL
    IOW, if the switch can turn the entire circuit off, it needs to be 20A, otherwise, as long as it is sized for the max load it can have, it is fine. Typically, that switch would turn a lamp on/off, and only if that load was the full value of the circuit or was dedicated to that single load, would it need to be a 20A switch.
  1. Residential Lights and Outlets on Same Circuit?
    By TomBrooklyn in forum Electrical Forum discussion & Blog
    Last Post: 08-24-2010, 08:08 AM
  2. Can I install outlets/switches before drywall?
    By ironspider in forum Electrical Forum discussion & Blog
    Last Post: 06-24-2010, 01:54 PM
  3. Adding 4-way switches to a 3-way lighting circuit
    By cej22 in forum Electrical Forum discussion & Blog
    Last Post: 11-14-2009, 07:39 PM
  4. Convert 220 circuit to 110 circuit to be run to new subpanel
    By C Willard in forum Electrical Forum discussion & Blog
    Last Post: 10-24-2009, 06:39 PM
  5. How Many Outlets Can Be On One Circuit
    By River Rat in forum Electrical Forum discussion & Blog
    Last Post: 08-20-2007, 02:47 PM
