Results 1 to 8 of 8
Thread: wiring for deep water submersible pump
    DIY Junior Member Skip Johnson's Avatar
    May 2011
    Kansas
    Default wiring for deep water submersible pump
    We will be installing a water filtration system powered by solar energy. The well is 150' and the distance from the wellhead to the solar/water "building" is 200'. The height of the tower holding the solar panels (4 140 watt panels) is 10'. What gauge wire will we need for that distance and depth?
    Mar 2011
    Houston, TX
    Welcome to Terry's Forum Skip,
    What voltage will you be using, and what is the current needed for your water filtration system ?
    Them items would be nice to know, so that you could get a better answer.
    Have a great day.
    DonL
    Feb 2011
    NW Ontario, Canada
    So, the wire run is 350 feet to the pump. Unfortunately you failed to provide any info on the pump. The info on the solar is not needed.
    http://www.aquascience.net/submersib...cfm?wiresize=1
    May 2011
    Kansas
    18 gmp, 230 volt 3 wire
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Also you need to know amp load and hp.Then go to the chart as stated above.
    GPM does NOT give use the amperage load. Three wire should mean two hots and a ground, but could be two hots and a capacitor start wire, but NOT three phase.
    Feb 2011
    NW Ontario, Canada
    One of the three wires on a 230V single phase system is probably protection ground. Capacitor start should be four wires. Three phase should be 208V and need more conductors.
    Exactly which is why we would have to know WHAT the third wire is, since if it IS a ground it is irrelevent to the discussion. And I have seen MANY 240 three phase systems.
  1. Deep Well submersible Pumps runs continuously.
    By hygron in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-25-2010, 09:54 PM
  2. Submersible vs combination deep jet
    By glenn388 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-08-2009, 05:52 AM
  3. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-20-2009, 09:33 AM
  4. Questions on deep well submersible pump
    By reddeuce in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-23-2008, 05:02 AM
  5. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-21-2007, 04:49 PM
