Results 1 to 3 of 3
Thread: Bathtub Drain
    DIY Junior Member tate16t's Avatar
    Dec 2006
    New York
    Default Bathtub Drain
    Hello guys,
    The pipe (#12) indicated in the attached diagram in my home is slightly damaged at the top (perhaps 1/4 of it) I'm assuming due to rust. I beleive I damaged it while atttempting to replace the drain. It's leaking slightly. Is there a fitting I can use to fix this, keeping in mind the correct height for the drain?
    http://www.terrylove.com/wwwboard/messages/9220.html
    If it has a "spring" on the end, then you HAVE a pop-up drain assembly and the "pop up" portion may be missing from the opening on the bottom of the tub. IF the lever is loose, it is worn out and you need a new cover plate and handle assembly.
    DIY Senior Member jerome8283's Avatar
    Oct 2006
    New York
    Are you replying to the correct post?
  1. 1 11/16 bathtub drain
    By rameok in forum Shower & bathtub Forum & Blog
    Last Post: 10-05-2008, 02:02 PM
  2. bathtub drain doesn't line up with existing drain
    By erich in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2008, 10:40 AM
  3. Replies: 1
    Last Post: 01-06-2008, 06:04 AM
  4. Laundry drain conundrum - drain CWM into bathtub?
    By vga4life in forum Plumbing Forum Discussion & Blog
    Last Post: 04-29-2006, 06:43 AM
  5. bathtub drain
    By deb8997 in forum Shower & bathtub Forum & Blog
    Last Post: 10-12-2004, 05:25 PM
