Results 1 to 5 of 5
Thread: How to fix an uneven lawn?
    DIY Junior Member breakpoint's Avatar
    Mar 2011
    Los Angeles, CA
    Default How to fix an uneven lawn?
    Hello all, I recently had my house repipe and a new an irrigation system was done. I start finding the lawn becomes uneven because workers digged up trenches for the pipes. Do you think I can just simply put dirt over those spots and wouldn't hurt or suffocate the grass (St. Augustine), or I should dig up the grass and put dirt underneath them? My concern is that after watering, the dirt and soil would sink again and by digging up the grass again I am afraid of killing them. Please advise.
    Mar 2011
    Houston, TX
    I would use sand, and the grass will grow thru it.
    And use a wheelbarrow , and not drive on it with heavy equipment or a load of sand in a truck, so the piping does not get damaged.
    Have a Great day.
    DonL
    Feb 2011
    NW Ontario, Canada
    If you use material that is different than the adjacent existing material, you will see a difference in the growth with varying moisture conditions. Best IMHO to match the existing material as close as possible.
    If there is a significant amound of subsidence, you would be best off to pull back the sod and fill beneath it, then roll out the sod over the fill and water it well.
    Mar 2011
    Houston, TX
    The original installer should have used sand when installing the pipe, if it was needed.
    Most likely the St. Augustine that you have is already growing in mostly sand, In your location.
    A good top soil may be best, But sand will work into your soil as good as anything, without disturbing the grass further.
    LLigetfa is correct about; "If there is a significant amound of subsidence, you would be best off to pull back the sod and fill beneath it, then roll out the sod over the fill and water it well."
    But St. Augustine will never grow the same if the soil is disturbed, It takes time for it to recover.
    DonL
    Feb 2011
    NW Ontario, Canada
    A good contractor would have put back on the top, the same material he took out, and left it a little proud to allow for settling.
    Years ago, I trenched in a wire across my front yard which is all heavy clay soil. It was just a narrow slit about an inch wide which was impossible to fill with the same gummy clay so as the clay dried out, it would crack open along the line, like a wound that would never heal. I managed to pulverize some dry clay and eventually filled it in to the point it no longer cracks open but to this day, I can still see by the difference in growth, exactly where that line is.
    There are several other places in my yard where I used different material for fill and in times of drought, they stand out like a sore thumb. I have to fertilize and water some areas differently to try to keep them looking even.
  1. Uneven wall/tiling
    By sue4072 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-27-2010, 08:07 AM
  2. I need to buy lawn mower blade, lawn edger and string trimmer
    By sangitaft in forum Lawn Care/Landscaping
    Last Post: 08-23-2008, 06:07 AM
  3. Uneven Flange
    By geandham in forum Toilet Forum discussions
    Last Post: 03-28-2008, 06:45 AM
  4. Uneven installation of new tub
    By C8M8M8 in forum Shower & bathtub Forum & Blog
    Last Post: 08-27-2006, 02:09 PM
  5. Uneven pressure after repair
    By Kenny747 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-01-2006, 02:55 PM
