How to be neat with Silicone Caulk?
Snowman
FLORIDA
blizphotos.wordpress.com
Hi,
I have tried for years to develop a "technique" for applying silicone caulk. That stuff drives me crazy :( . No matter how hard I try, I can not smooth it out like the latex/silicone stuff. Plus it is the messiest stuff to try and get off of ANYTHING. I know it is an excellent caulk, but so hard to work with.
Would someone do a good deed and tell me (us) the secret to working with the stuff and getting a nice smooth bead with nice smooth edges. How do you tool it?? How do you level it out??
Thanks, Tom :rolleyes:
PEW
DIY Senior Member
Another suggestion, don't over apply before smoothing out. It is very easy to apply an excess amount. I have also found a wet finger one of the best tools around.
Paul
Jimbo
San Diego, CA
Some folks take the time to put a masking tape border on the seam. Then you can be a liittle messy with smoothing the caulk, and peal the tape.
I don't like silicone that much, but it does last longer. I do always use in on the inner seams of shower doors. I like the DAP Kwikseal much better for most applications. PolySeamSeal is also very good.
SRdenny
Plumbing Contractor
SF Peninsula
I'm with Jimbo when it comes to Polyseamseal. Dap is a bit runny for me. As for Silicone caulk; when I have to use it, I keep a can of denatured alcohol and a clean rag handy for cleanup. If you want expert advice on Silicone caulk, you should ask a glazer who specializes in shower walls and doors. They can work magic with the stuff.
Cal
Northern Virginia
Silicone is the WAY to go !! Most folks have had a bad time with it because they treat it like regular caulk .
DO NOT cut the end at a large angle . DO NOT try to go over it again while it is wet .
Cut a small angle and hole , run the silicone in a steady bead , wipe with a clean index finger .
After application, clean your hands with de-natured alchohol (sp?) or something that will get it off .
Been doing this a LONG time and have found if I slow down ,,,,, it works out SO much better !!
Cal
Dunbar Plumbing
www.KoldBreeze.com
I don't have to use caulk that much in plumbing, maybe around chrome trim or the backsplash of a vanity. I've probably only laid one good bead in my life. I know where and what it was, it happened by accident and whatever I did, the customer was watching and he couldn't believe how good it looked. I've done numerous jobs since then just here and there around trim in a tub or shower, can't seem to match it. I don't know if anyone else experiences this with age but my hands shake when doing detail work. Not a whole lot, but I catch myself noticing it every now and then. Don't smoke or drink caffeine either. Someone called my caulk job a bunch of gorilla turds once...what can I say :eek: :rolleyes:
Snowman
FLORIDA
Thanks very much.
Great tips........ Yes, Paul, that was one of my problems.
Jimbo, srdenny, and plumber1, I have always had good smooth beads with Polyseam Seal too.
Cal, that's what I'll try next time with the silicone. Thanks! Never knew about the denatured alcohol that you and srdenny suggested. :)
RUGGED, that sounds like some of mine.. :rolleyes:
Thanks guys, Regards, Tom
Jimbo
San Diego, CA
On the alcohol, I think isopropyl ( rubbing alcohol ) works, but denatured works much better. It is available in all the paint stores, depots. etc.
Douche
Delaware
There is a small tool that you can buy at Lowes or HD that really smooths the caulk nicley. Its shaped like an arrow head w/ a handle except the tip is rounded. Does a nice job...
Markts30
Commercial Plumber
Phoenix, AZ
Another trick I use for silicone is to put the bead on and then smooth it with my finger dipped in liquid soap.
It smooths really well and doesn ot stick to the soap so no residue on the finger to clean off....
petergunn
back of fingernail
Warning: Advice from DIY Newbie
For some reason I like caulking. Ive caulked all around the windows in my house, around tubs, showers, etc. even filled in the cracks in the baseboards and coving. Now, while I'm probably using the wrong caulks in the wrong places I have mastered the art of getting nice neat flat lines.
Here is what I do:
1) Caulk roughly along the edge - try to get a reasonably even bead. I go all the way around the tub in one go then go back and fill in any bits I missed.
2) Run your index finger along the seam in one direction from end to end, then go back in the other direction using the back of your thumb nail. I wear latex gloves. When done right this displaces the caulk into 3 lines - a nice neat line in the seam, and rough ones from the dispolaced caulk on the tile and tub. Key is that there is an area between the seam and the displaced caulk that is completely clean. You may have to wipe your hands a few time if you put to much caulk on at the start.
3) Wait a few minutes until the rough lines have started to set but are still soft, then go around with an old credit card and peel them off. They should come off easily and leave little or no residue.
Result is a perfectly smooth seam with no fussying.
Works for me :)
Steveg91
Hi all, Is denatured alcohol likely to harm escetcheons, satin or chrome???
Thanks, Steve
