Results 1 to 8 of 8
Thread: Is it a Gas Valve or a Water Valve?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Is it a Gas Valve or a Water Valve?
    Hi,
    I was told by a natural gas company service person that a ball valve (shut-off) in a 1/2 inch gas line was for water and not gas.
    How can he tell the difference? This is an older valve with no labels. Many ball valve shut-offs are for water and natural gas.
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    What color is the handle?
    I bought a bunch of valves today,
    THe gas valves had yellow handles on them.
    On the side in the casting it had "1/2 psi"
    Not sure what the other colors are off hand, Red & Green....
    Michael
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    Nov 2010
    Maine
    It will have WOG stamped on the valve. (water-oil-gas)
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    Default Handle Color not the Clue !
    I would not go by the color of the Handle. I have many yellow handled Water ball valves and even a Blue Handle Gas valve.
    Most have a rating stamped on them. You will see WOG on the side. This stands for Water, Oil or Gas. Most gas valves are brass and much heavier than standard valves. The difference is in the internal sealing of the ball. Gas valves are better.
    Most of the ones I could check have WOG on them. I have 1 with just a G on it . Also don't go by the Handle type either as I have a gas Ball valve with a long handle (Red).
    Possibly there is some other evidence that will help. The 1/2 psi indication , if there is no G would make me think it is for water but I am not a valve manufacturer.
    Kevin
    The color of the handle usually identifies the manufacturer, NOT the valve's usage. Valves with WOG on them are for liquid gas, unless they also have the AGA tag. Technically, they are NOT natural gas valves but do function for that purpose. AGA certified valves are usually less expensive, however.
    Sep 2006
    cold new york
    The ball-valve had a red handle and no markings. I do not know how the gas company determined it was a water valve and not a gas valve.
    Gore Vidal.
    Usually, just by looking at it. Gas valves have a distinctive appearance. The red handle just happens to be the color the manufacturer liked.
    Plumber jimbo's Avatar
    I don't know if we have a definitive answer here yet. I always thought that to be used for gas, the valve had to be AGA listed.
  1. Combo ball valve/check valve for ejector pump...
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2009, 12:27 PM
  2. Toto Fill Valve Problem Continues G-Max valve with adjusting screw
    By levitonski in forum Toilet Forum discussions
    Last Post: 12-02-2008, 12:40 PM
  3. Why is sink shutoff valve still leaking after main water valve turned off?
    By kimana517 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2008, 06:28 PM
  4. Detail question relating to sewage pit check valve and shut off valve.
    By Longwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2007, 05:17 PM
  5. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
