Page 1 of 9 123456789 LastLast
Results 1 to 15 of 126
Thread: Opinion on expansion tank installation. Picture included.
    DIY Junior Member John Vega's Avatar
    May 2011
    Florida
    Thumbs up Opinion on expansion tank installation. Picture included.
    I am not an experienced plumber, however I am a little paranoid that the expansion tank that was recently installed in our home may eventually cause the pvc piping to fail due to the weight, stress being applied by the tank/fittings.
    Attached is an image of the install. Should I be worried?
    you should be worried about that, but maybe more so that the CPVC plastic is attached directly to the tank. There should be AT LEAST 18" of copper between the tank and the plastic, with the expansion tank attached to the copper and PROPERLY supported with hangers or anchors.
    May 2011
    Florida
    Thanks for the quick reply!
    Dec 2009
    northfork, california
    Curious if you had a licensed plumber install that joke bit, or was it a mentally challenged handyman?
    Dont be worried. Be ANGRY.
    May 2011
    Florida
    Quote Originally Posted by ballvalve View Post
    Yes. Bayonet Plumbing, Heating & AC, Inc. http://www.bayonet-inc.com
    They are a contractor for Lennar homes.
    May 2011
    Florida
    The company replied to my email:
    " It is mounted correctly, however, if you would like it removed we can send someone out to do that for you.
    In reguard to the 18" of copper pipe: That is a requirement for gas water heaters. It is not required for your electric water heater."
    I am talking with them now via email to come up with a solution to the install issues.
    Mar 2011
    Houston, TX
    LMAO...
    Nice Rigging...
    Feb 2005
    Omaha, NE
    When that tank eventually fails, it will fill with water. (Right now, it is partially filled with water, partially with pressurized air, and they are separated by a rubber diaphragm.)
    When it is all filled with water, it will be very heavy, and will tip to one side, and will twist the pipe it is attached to, most likely breaking it.
    It needs to be properly supported, in such a way that it will be stable when it is filled with water.
    Jun 2009
    Canada
    Quote Originally Posted by John Vega View Post
    So regardless of fuel type both heaters put out hot water... Wow...
    Dec 2007
    In Florida the 18" is not a code requirement on electric water heaters.
    The primary concern there is heat damage from the hot flue, not 120 degree water in the tank.
    However they do need to adequately support the expansion tank or it will break off the CPVC if it ever becomes waterlogged.
    CPVC, IMHO is a junk material.
    Dec 2009
    The best part is the glued in valve butted to the wall that cost $1.98 from Indonesia.
    May 2011
    Florida
    Thanks for all of your feedback!
    I have done some searching to try and find what the installation "should" look like. I have come up empty handed.
    Do any of you have a diagram or picture of an installation which is done properly?
    The box that Watts tanks come in has suggested methods for installations. What you have is not one of these methods. If I was a professional plumber, which I am not, I would be ashamed of this installation. Not only for how the tank is installed, but the rest of the installation as well. Others have already chimed in on the problems, so no need to restate them.
    May 2011
    Florida
    Wow, thats great to hear
    Dec 2007
    Wow, thats great to hear lol...
    Crazy thing is HUNDREDS of Lennar homes are plumbed exactly like mine except they don't come with an expansion tank by default.
    I guess if it passes minimum code, you are good to go!
    The Plumbing Code is a minimum standard.
  1. re: bathroom sink leak on new installation -picture included-
    By gramps416 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2011, 07:52 AM
  2. Help Removing Moen Part from Tub/Shower Valve (picture included)
    By nuglas in forum Shower & bathtub Forum & Blog
    Last Post: 02-05-2011, 12:41 PM
  3. Expansion Tank Installation
    By Roccoo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-02-2009, 05:49 PM
  4. New Expansion tank installation....necessary ?
    By rcatty in forum Water Heater Forum, Tanks
    Last Post: 06-02-2009, 07:07 AM
  5. Expansion Tank Installation
    By BigSkeet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2008, 04:11 AM
