Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: HELP ME with this pipe size...
  1. #16
    DIY Junior Member TURBOSCHILZ's Avatar
    May 2011
    DENVER, CO
    Thanks for the info Don, I've been looking thru it, but have yet to find anything out of the ordinary, but will keep looking... Thanks again for all your help...
  2. #17
    Mar 2011
    Houston, TX
    Maybe that is 1 inch Poly.
    Enjoy your day.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  3. #18
    May 2011
    DENVER, CO
    Originally I hard purchased a 3/4" and 1" barb fitting, but of course the 1" was way too big, the pipe could probably fit thru the middle of it...lol The size difference is VERY minor, but it is enough to cause a slight leak around the 3/4" barb... Thanks for all the help Don, you do the same...
  4. #19
    Mar 2011
    Houston, TX
    If you have a heat gun Turbo, then you can heat the pipe and then clamp it down, and be done with the parts that you have.
    Good Luck.
    DonL
  1. gas pipe size
    By randolph56 in forum Water Heater Forum, Tanks
    Last Post: 02-15-2011, 03:05 AM
  2. Pipe size for pipe to water tank.
    By odysseus99 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-02-2011, 12:12 PM
  3. Pipe Size
    By Pochi in forum Irrigation / Sprinkler Forum
    Last Post: 07-04-2009, 11:13 AM
  4. Pump Size, Pipe Size, CSV location????
    By fausdick in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2009, 05:40 AM
  5. what pipe size with 5/8" meter, to replace old pipe?
    By sbaitso in forum Plumbing Forum Discussion & Blog
    Last Post: 01-05-2006, 07:18 AM
