I asume you are talking about poly pipe. I have never seen a male/male barb fitting that could be inserted without first heating up the poly to expand it. Pipe is normaly spec'd by the ID, not the OD so the thickness of the wall should not be a factor.
Are you sure you are using the right barb fitting?
