Thread: PEX Connections
    DIY Junior Member countrylife's Avatar
    May 2011
    Texas
    Default PEX Connections
    I have a PEX pipe coming out of my slab that has a black interior, a shiny metalic layer, then a gray outer layer. I'm assuming it's the aluminum oxygen barrier PEX. The outside diameter is .9375 (15/16") so the 3/4" crimp rings I get at Lowe's will not fit.
    Note: it appears that the outer layer of gray has been removed to put a fitting on originally. Experimenting with the pipe and removing the gray puts the metal layer at just over the .875" that is specified for 3/4" pipe. I can't believe that this is the right way to terminate the pipe.
    What kind of crimp rings are supposed to be used for this pipe?
    The fittings and crimp rings made FOR it. It is probably Pex-Al-Pex which was normally only used for infloor heating systems. Hopefully your brand is still in production, because some companies have abandoned the material.
    May 2011
    Texas
    I talked to a couple of different plumbing houses today and found out that the pipe is Viega Pex. Also found out that as part of the fitting installation a "reamer" is used to reduce the outside diameter of the pipe. I don't know anything about Viega yet, but I'll read up on them.
  1. ABS to PVC Septic Connections
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2011, 06:01 PM
  2. Al to Cu Cooktop Connections
    By TubeGuru in forum Electrical Forum discussion & Blog
    Last Post: 09-09-2010, 05:57 AM
  3. S-Connections
    By Nettlewarbler in forum Shower & bathtub Forum & Blog
    Last Post: 08-24-2009, 06:23 AM
  4. Shallow well connections
    By Brian78753 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-11-2008, 06:06 AM
  5. PEX connections
    By Wrenn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2006, 10:37 PM
