Results 1 to 15 of 16
Thread: Connecting Hot Water Heater Drain Pan to Sewer - Will Swing Check stop sewer gas?
Hybrid View
    DIY Junior Member Jim109's Avatar
    May 2011
    Texas
    Default Connecting Hot Water Heater Drain Pan to Sewer - Will Swing Check stop sewer gas?
    Hey all!
    So I had a plumber out to make my water heater drain pan:
    drain to somewhere else other than the garage as I am building out the garage to use as a room. He ended up connecting the drain pan to the sewer in the wall next to the hot water heater as it has sinks on the other sides. He used a swing check valve:
    to stop the sewer gas from going back into the water heater closet. My question ... is this sufficient to keep the sewer gas out? I have a feeling that its not and there should be some sort of P-Trap or something else to keep the gas out. I haven't been able to smell any sewer smell in the hot water heater closet yet but I am very concerned that it might be letting small amounts of gas through. Any help here would be much appreciated.
    Jim
    Aug 2009
    South*East
    There is no way what he did is correct. At the least it should be connected to a indirect waste with a properly sized air gap. He has created a very dangerous condition.
    John
    Jun 2009
    Canada
    There is no trap seal, and there is a chance of gas, or back flow...
    May 2011
    Texas
    So it sounds like I need to get this looked at again. Can you give me a little more details on what indirect waste is and how you create a properly sized air gap? Is it a dangerous condition because gas can leak out into the house? I'm trying to get more details so if I do need this fixed I know what SHOULD be done
    Thanks so much!
    Quote Originally Posted by johnjh2o1 View Post
    John
    May 2011
    Texas
    One additional question.. I should be able to smell the gas if its leaking right? I would think the swing check wouldn't stop the gas but I can't seem to smell anything. I wonder if the proper solution here would be to go through the wall to the sink on the other side and connect to it before the P Trap like the A/C units do. Would that be the proper solution or is there a way to fix it without doing that?
    Thanks!!
    It's strange what he did, but I doubt you will be smelling anything. I would be more worried that it won't drain. Those are normally placed on water supply lines under pressure.
    We drain water heater pans and relief lines either outside, or to an indirect drain.
    Depending on the situation, some drain lines don't really smell much, so no, you may not smell anything. Yes, this should be corrected, and if the guy is licensed and it was done with a permit, a call to the inspector would get fast action.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    Again the point is that you want to see if there is a problem.
    If the water heater is leaking you want it to dribble on the floor and piss you off enough to call a plumber.
    That is the point! Do not route the drain from the drip pan to a hidden point do not hide any problems that may occour.
    If there is a problem you want to know before it becomes dangerous!!!
    Michael
    Michael
    Sac City Plumbing
    http://SacCityPlumbing.com
    May 2011
    Texas
    Thanks for the reply! Can someone explain what an indirect drain is. I'm thinking of having it go to the bathroom drain before the P Trap ( Just like my AC unit does in a different bathroom). Is that an indirect drain like you are referring to?
    Thanks again!!!
    Jim
  1. Swing Check vs. dual check vs. double check valve
    By colbymom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2011, 01:19 PM
  2. Design, connecting shower and washing machine drain to the same sewer pipe.
    By Florin in forum Shower & bathtub Forum & Blog
    Last Post: 10-18-2010, 08:54 PM
  3. Connecting to Storm Sewer?
    By Nate R in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2009, 09:44 PM
  4. Connecting to City Sewer Main
    By jaxbldginspector in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-02-2008, 08:54 PM
  5. connecting outdoor sink to sewer
    By marlachat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2005, 05:26 AM
