Inside every one I've seen, there is a label that clearly states the acceptable lamps it can accommodate...so, take a look and heed the manufacturer's instructions. They aren't all created equal, so you need to read the instructions on YOUR fixture. Also note, there may be a difference when using an enclosed trim verses just a reflector, so make sure to read carefully, or find it on the manufacturer's website for that model.
