Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: How often should you test t/p valve on water heater
  1. #16
    Dec 2007
    Quote Originally Posted by master plumber mark View Post
    I have never touched them and it is best not to because ..
    YOU ARE BASICALLY PULLING THE PIN ON A GRENADE
    If you FIRST clearly state to the customer BEFORE you touch the t+p valve that it might start leaking right NOW, or later today or tomorrow or next week , and its gonna cost you $$ to change it out...
    My guess is odds are that they will tell you to leave it alone.....
    If you do leave it alone you are probably leaving a bomb in their home....
  2. #17
    Feb 2005
    Cool Redwood ....please..........
    Quote Originally Posted by Redwood View Post
    Redwood, you know that this is a total load of hooey..
    I do think it is something that I might start to mentioin to my customers when I go into their homes...
    I would inform them that it would be a good idea to change it while I am at their home for $$ 125.00..
    I will not test the T+p valve cause I know it will leak...
    but I will gladly change it for safety sake
    I dont think i will get many takers.....even at 125
    not in this economy
  3. #18
    DIY Member dargo's Avatar
    Jan 2010
    MA
    Well boys, in 25 years owning personal and renting homes, never messed with them. Not worth the time etc..Most time the tank will be shot before the valve...YMMV.
  4. #19
    Dec 2007
    not in this economy
    Actually Mark I do test them and far more test good than fail.
    Of course your water conditions may be quite different from what I routinely see.
    I'm not kidding when I say bomb and you know it Mark...
    Of course the need of this critical safety device is limited to a situation where the thermostat has failed causing run away heating of the water and the ECO has also failed. It is a third in line device. But it is highly desirable to have it working.
  1. Water Test - What to Test for?
    By asmart82 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-01-2011, 09:19 AM
  2. air test vs water test
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2009, 11:40 PM
  3. Water Heater Pressure Relief Valve Leaked About a 2 Quarts of Water
    By hudson in forum Water Heater Forum, Tanks
    Last Post: 07-06-2009, 11:51 AM
  4. Valve leak at pressure test
    By jonwarner4 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2008, 01:20 PM
  5. DWV cleanout plugs weeping & test plug blowout during water test
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2006, 11:38 PM
