Results 1 to 2 of 2
Thread: Closet Flange level to finish floor but gap to sub floor
    DIY Junior Member boardryder's Avatar
    May 2011
    CT
    Default Closet Flange level to finish floor but gap to sub floor
    Hi All! Hopefully I can describe this without a picture.
    I have a closet flange that is level to the hardibacker board and 1/4" below the finish tile floor which should be fine to install with a possible extended wax ring. The problem comes in that there is actually a gap of 3/4-1" between the bottom of closet flange ring and the old plank subfloor. It's an old lead pipe and in tact flange with the hardibacker fit snug around the flange so not much rocking could happen and it would take a lot to move the pipe up and down. Will I be safe with the gap as long as I anchor the flange in place? Also, the subfloor where the anchors would screw in may not hold a screw, due to years of wear and replacements. Any input on that? Maybe something to fill the gap?
    I'd be concerned with the lead pipe. Any movement, rocking or up and down, will break the wax ring seal. As far as anchoring into the old plank subfloor, you could use plastic or lead sleeves into the planks then #12 stainless steel screws into them. I use lead sleeves into concrete anytime I need to attach or anchor anything and they will hold forever. Plastic would probably work OK as well. But, I'd sure deal with the lead pipe situation. Better to spend some time and perhaps $$ now while you're at it than regret it later when you have to rip up the flooring and redo the job.
  1. Toilet flange above or level with floor
    By dmaceld in forum Toilet Forum discussions
    Last Post: 04-25-2012, 06:36 AM
  2. Toilet Flange well below floor level
    By leorob in forum Toilet Forum discussions
    Last Post: 11-15-2009, 07:43 PM
  3. closet flange and new floor
    By xj-boonie in forum Toilet Forum discussions
    Last Post: 06-23-2006, 09:37 PM
  4. flange too high, floor not level
    By julia in forum Toilet Forum discussions
    Last Post: 01-09-2006, 06:58 PM
  5. Flange doesn't sit level on floor -- HELPPPP!
    By grace under pressure in forum Toilet Forum discussions
    Last Post: 06-05-2005, 10:25 AM
