Results 1 to 9 of 9
Thread: Air Handler Access
    DIY Senior Member jerome8283's Avatar
    Oct 2006
    New York
    Default Air Handler Access
    I have central air in my new home (new to me but old in age). I noticed the air handler requires what looks like a key which I do not have. Is there a standard key for this or is this not a key and some sort of tool?
    No idea, but it's hard to tell without some brand and maybe model info...we can't see it to tell! Most that I've seen only require a wrench or screwdriver to open.
    Oct 2006
    New York
    You’re a genius! I'mi such an idiot! A srewdriver worked.
    Oct 2006
    New York
    Jim -
    Obviously, this is my first time opening this. I was prompted to open it because of a musty smell that I get from some of the registers. The evaporator coils are rusty. Is this something I should be concerned about? The unit ran fine all season last summer. I have not turned it on yet this year.
    The coils themselves are probably copper, the support framework might be something that can rust. Ideally, they'd use metals that can't rust since the evaporator coil generally is wet while running. A good cleaning may get rid of the musty smell. You want to ensure that the drain is clear as well. If you aren't careful, though, you can bend the fins and decrease the efficiency of the unit.
    How old is the coil? If you can post a picture, the pros may have some suggestions.
    Oct 2006
    New York
    Thanks Jim. I will post pics tomorrow. The unit is more than 12yrs old.
    Oct 2006
    New York
    Here are some pics. I also found instructions in side the unit, VDX/VHE Series Fan Coil Unit?
    First thing noticed is that it could use a good cleaning! Other than that, see what the pros have to say.
    Oct 2006
    New York
    Yeah I'm planning to do that.
  1. covert three handler shower faucet to one handler
    By oz19454 in forum Shower & bathtub Forum & Blog
    Last Post: 07-10-2010, 04:54 PM
  2. Air handler in closet
    By jetlag in forum HVAC Heating & Cooling
    Last Post: 12-13-2009, 11:14 AM
  3. Trapping an air handler
    By Lightwave in forum Plumbing Forum Discussion & Blog
    Last Post: 12-11-2009, 04:59 PM
  4. A/C Condenser and Air Handler
    By seaneys in forum Electrical Forum discussion & Blog
    Last Post: 11-30-2008, 07:13 PM
  5. Variable speed or std. air handler?
    By estone in forum HVAC Heating & Cooling
    Last Post: 10-28-2008, 03:24 PM
