Results 1 to 7 of 7
Thread: Eroded hole in older sink
    DIY Junior Member Atomic Teaspoon's Avatar
    May 2011
    California
    Default Eroded hole in older sink
    I am in the process of buying a house and the list of things to fix is endless. It is a 203k loan, so every little thing has to be documented by a contractor (had one quote $50 for installing smoke alarms).
    Anyway, the main bathroom has an older (house built in 79) sink with a hole eroded right near the drain, less than a half inch in diameter. Is there a legitimate fix that would patch that hole and satisfy building code? I'd much rather be able to do a temporary repair now and come back to replacing the sink, reinstalling fixtures, and retiling the countertop at a later date. Is there a feasible way to do this?
    Jan 2008
    You'd be better off getting an inexpensive or used sink and throwing it in there. I see people giving them away all the time after they remodel.
    May 2011
    California
    That's great to know. I didn't know used materials could be utilized.
    Here a nice sink that was thrown away. It was rusting out from below and rusted above.
    Even a brand new steel sink is not expensive and would work for you just fine for as long as necessary. It's when your start getting in to cast iron and upper level fixtures that the money gets serious.
    "Code" does NOT care what the sink looks like, just that it work properly. Make any kind of repair you will be happy with.
    Dec 2007
    Quote Originally Posted by Atomic Teaspoon View Post
    You consider that to be a bad price for someone to purchase a smoke detector, drive to your home, install the smoke detector, using tools they own and maintain, then drive home or, back to their shop again?
    I wouldn't do it at that price... I'm thinking 3 - 4 times that amount before I would barely consider it!
  1. Older Friedrich Grohe bath sink faucet repair
    By Bill Anderson in forum Plumbing Forum Discussion & Blog
    Last Post: 07-18-2010, 04:33 PM
  2. sink hole cutout mistake
    By senbabli in forum Remodel Forum & Blog
    Last Post: 10-31-2009, 08:04 PM
  3. Where do I get sink hole caps?
    By benxiaohai in forum Remodel Forum & Blog
    Last Post: 01-11-2008, 07:11 AM
  4. Three hole vanity sink
    By HoneySuckle in forum Plumbing Forum Discussion & Blog
    Last Post: 11-28-2006, 04:33 AM
  5. Replies: 4
    Last Post: 10-02-2006, 03:45 PM
