Results 1 to 5 of 5
Thread: sandy water has caused toilet problems
    DIY Junior Member Rue D'or's Avatar
    Jun 2006
    Lafayette, LA
    Default sandy water has caused toilet problems
    I recently had the foot valve changed on my shallow water well... as usual, it blew a bunch of sand on restart. we let it run for five or ten minutes to blow most of the sand out, but still got a lot in the house plumbing.
    all three toilets are out. two will flush if you fill the reservoir with water... the fill hose seems to be running fine, but the reservoirs wont fill. is this some sort of problem with the bowl fills being clogged? if so, any recommendations on fixing.
    the third toilet won't hold water at all. even if i pour enough water into the reservoir, it just all drains. any ideas?
    Thanks in advance.
    Moderator valveman's Avatar
    Mar 2006
    Running the pump for hours or days instead of minutes may help clean out the sand. Adding a filter can keep the sand out of the house. But you may want to post this in the plumbing section to get some help with the toilets.
    Jun 2006
    Lafayette, LA
    thanks i'll try that...
    btw... any recommendations on where to place the filter? somewhere inline directly on the pump outlet or between the pumping equipment [well house] and the house?
    thanks
    Mar 2006
    It is best to put filters after the pressure tank, but it doesn't always work out that way.
    Jan 2008
    Virginia Beach, VA
    By your description it sounds as though the flappers in 2 the commodes are leaking and the third one may be bad or stuck open.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Brown and sandy well water
    By njrick in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-11-2011, 04:01 PM
  2. Replies: 4
    Last Post: 07-06-2010, 09:58 AM
  3. Low pressure caused by single handle faucet?
    By RAM1961 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-26-2010, 05:30 PM
  4. Debris caused PRV to fail.
    By NWh2o in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-21-2009, 03:36 PM
  5. repair caused *no* wash
    By pmurray in forum Toilet Forum discussions
    Last Post: 04-14-2007, 04:14 PM
