Results 1 to 14 of 14
Thread: odd leaking faucet, Aqua Dynamic
    DIY Junior Member anon125's Avatar
    Jul 2009
    British Columbia
    Default odd leaking faucet, Aqua Dynamic
    if this is on the wrong forum, please move it to the right one!
    the exterior faucets are the kind for cold weather, so they are about a foot long - inside the house.
    the shaft the handlle is on has a little hole in it.
    on one, that is where the water comes out!
    what is wrong?
    thanks
    Aug 2009
    South*East
    Sounds like you didn't remove the hose from it last winter causing the faucet to freeze and break.
    John
    Jul 2009
    British Columbia
    hose was removed - thanks
    A frost free sillcock uses a long shaft on the handle to turn the actual guts of the valve way at the other end. So, if it is leaking, it may need a rebuild kit to replace the sealing washer and or seat. Also, most frost-free sillcocks will still split if you happen to leave a hose on it with a closed nozzle...it then can't drain. If the shaft isn't sloped properly, it can't drain, and could freeze, too.
    Sounds like new parts then.
    You should be able to order them from the manufacture.
    Jul 2009
    British Columbia
    see fountain!
    Jul 2009
    British Columbia
    has anyone seen aanything like this?
    thanks all
    Not really.
    What is the brand name of the faucet?
    Jul 2009
    British Columbia
    do these help
    i suspect that rubber valve on top.
    thanks
    Not really.
    Jul 2009
    North Vancouver, BC
    Annon I use similar exterior hose bibs on my projects here in Vancouver but prefer the 1/4 turn models. I suspect that that shut is missing a bleeding cap of sorts where you are getting the water stream from.
    Try bringing it to EMCO or Bartle & Gibson for replacement parts.
    Good Luck.
    JW
    Jul 2009
    British Columbia
    Quote Originally Posted by johnfrwhipple View Post
    Good Luck.
    JW
    thanks....
    Jul 2009
    British Columbia
    Quote Originally Posted by anon125 View Post
    does anyone know why the water comes out that little hole in the rod thingy?
    we replaces the end piece where the washer are. did not help.
    thanks all
    Jul 2009
    British Columbia
    Hello again folks!
    well we found a new inner piece and so far it works.
    it does not creak any more when opening/closing.
    the only difference i see is that the new one has grease on the deep inside thread.
    what kind of grease is it?
    could that have been the problem all along!
    thanks all
  1. Aqua Touch Kitchen faucet
    By littlebrook in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-14-2011, 01:35 PM
  2. Hans Grohe Aqua Era Kitchen Faucet
    By craiginator in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2010, 04:33 AM
  3. Aqua Touch model 7811 kitchen faucet
    By ssambursky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2009, 08:07 AM
  4. Aqua booster is leaking and need to bypass
    By katamara in forum HVAC Heating & Cooling
    Last Post: 08-07-2008, 04:20 PM
  5. Dynamic pressure drop after regulator?
    By Vitaliy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2005, 06:21 PM
