Thread: sprinkler timer cycling
    DIY Junior Member gooseloony's Avatar
    May 2011
    el barrio, CA
    Default sprinkler timer cycling
    I replaced a sprinkler timer recently (Orbitz) and now my sprinklers keep cycling through and won't shut off until I maually shut them off. Any ideas as to the problem? Thanks in advance
    Either it is defective or is programmed improperly. NOTHING we can do to diagnose it without being there.
    Try doing this there might be overlapping start times programmed. Clear all start times and then enter only one start time. If you would like to water more than once a day, enter the next start time for later in the day. A start time is the initial time of day when the timer will begin to water. Each station or zone will then water in sequence according to its chosen duration. Multiple start times allow you to water all stations more than once in the same watering day.
  1. Toro Greenkeeper sprinkler timer PCB resistor problem
    By garyward22 in forum Irrigation / Sprinkler Forum
    Last Post: 04-08-2010, 09:01 AM
  2. toro lawnmaster sprinkler timer
    By george moneta in forum Irrigation / Sprinkler Forum
    Last Post: 06-12-2009, 07:50 PM
  3. Sprinkler Timer
    By maverick30900 in forum Irrigation / Sprinkler Forum
    Last Post: 08-10-2008, 05:36 PM
  4. Hydrotek 1114 timer quit/installing RB timer help!
    By vics44 in forum Irrigation / Sprinkler Forum
    Last Post: 02-21-2008, 05:40 AM
  5. Sprinkler Timer
    By ed the head in forum Irrigation / Sprinkler Forum
    Last Post: 03-08-2007, 06:18 PM
