Results 1 to 8 of 8
Thread: Kinetico Model softening 50% of time
    DIY Junior Member snifferpro's Avatar
    May 2011
    Phoenix, AZ
    Default Kinetico Model softening 50% of time
    My model 50 is only softening water 50% of the time.
    I completely emptied the salt tank and cleaned it out thoroughly. There was a lot
    of salt debris under the plastic shelf that I removed. I then replaced the plastic
    table and put just enough salt on top so I could see what happens when the unit
    regenerates.
    The unit regenerates on it's own about every three days. When regeneration starts,
    water is sucked out of the salt tank and then maybe 10 minutes later water is
    returned to the tank.
    Operation seems normal, but water is only soft when the Remote tank is in service.
    I verified this with Hach Test strips and when the Main is in service, no soft water.
    When the Remote is in service I get soft water.
    Can the 2 tanks be swapped so that the Main becomes the remote and the Remote becomes
    the main. This should prove whether or not the resin in the Main tank is bad.
    Am I correct in this assumption.
    I have been tracking the tank in service for over a month and results are very
    consistent. Remote in service - soft water. Main in service - no soft water?
    How easy is it to swap the tanks and does anyone have a diagram on how to do this?
    Suggestions?
    Dec 2009
    Alaska
    One can change tank 1 with tank 2, as the remote or 2nd tank adapter unscrew off the tank and the main valve body unscrew from its tank.
    But doing so is most likely to continue the same 50% of the time treatment of the water. More likely there is either something wrong with the main valve body in its water flow to tank 1 when it should be treating the water or that the distributor is no longer in the valve body within the tank.
    I know that in the Fleck 9000 or 9100 this would either be the lower piston with its seals and spacers going bad in keeping the water flow the way it should be or that the distributor tube out of place.. but the Kinetico is a bit different with its plates and the parts within the plates.
    May 2011
    Phoenix, AZ
    Switching tanks would verify that the resin is good inboth tanks and that the main valve
    body is bad.
    Anybody know what the main valve body should cost?
    Dec 2009
    Alaska
    It would do that , in verifying that both media beds are good or for some reason on has gone bad and the other is still good.
    The price is set by the Kenitico dealers, there are some rebuilt bodies from time to time on that sell and buy site .... starts with an E...
    Right now there is a Kenitico 50 in Oregon,, number for it .. 110686494210..
    DIY Member rjh2o's Avatar
    May 2011
    Michigan
    You have a bad quad valve in level 2 causing it not to switch tanks during regeneration. This level will need to be rebuilt by Kinetico.
    RJ
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by rjh2o View Post
    RJ
    The OP stated that he gets soft water from one tank then hard water from the other. How can you say it is not switching tanks?
    May 2011
    Michigan
    Right you are! Never the less, when the tanks switch if the quads do not seal properly, for that particular tank, the unit will not regenerate properly and hard water occurs.
    RJ
    Nov 2010
    Ocala, Florida
    RJ
    I have seen when one of the check balls is out of place the unit unit will draw brine for 1 tank but not the other. But, unless you have taken the valve apart, the check balls will stay in place.
  1. Kinetico Model 60 Connections
    By tmandreas in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-31-2009, 10:22 PM
  2. Kinetico Model no. 30 Problems
    By Mobster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2009, 01:41 PM
  3. kinetico model 30 help
    By hattrick37 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-26-2009, 06:55 AM
  4. kinetico model 30 help
    By hattrick37 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. Kinetico model 60
    By ErikM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2009, 09:58 AM
