Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Which is the best Pressure Assist Toilet?
    DIY Junior Member exoricst's Avatar
    May 2011
    Chicago
    Default Which is the best Pressure Assist Toilet?
    Hi all,
    I am looking forward to remodel my house, and bathroom is on the top of the list, Luckily I found this forum, and this place will keep me busy for a very very long time.
    Currently I am looking forward to install two Pressure Assist Toilet in two of my bathrooms.
    But am in a great deal of delimma at the moment. Unable to deciede what brand to go for.
    I am on a budget.. max i could go for is 350-400 dollars per toliet.. lower the better I was researching this forum, and i found people raving about FlushMate system for pressure assist. But i guess its just a part that needs to be installed inside the toilet tank. But I dont want to get into all that hassle, instead want to buy one off the shelf whole toilet pressure assist system which is below 400 dollars.. again lower the better. It wud be great if any brands carry inbuilt flushmate part.
    I was looking at Kohler Wellworth Power Lite Pressure assist toilet, but i am not sure if they are any good.. i also read, Kohler brands are prone to clogging a lot.
    Hence the confusion.
    Can someone guide me on what pressure assist toilet brand / make /model i can buy.
    Greatly appreciate all the help from the guru's in here.
    May 2011
    Chicago
    While going through this forum, and various reviews, i found another brand TOTO Ultramax elongated One piece toilets, how do they fare against pressure assist technology??
    There are 5 problems with pressure assist toilets. First they really don't work any better than a well designed gravity flush (Toto) Second, they are extremely noisy when flushed. Third, they splash, and fourth, when they break, and since they are a mechanical device, they will break sooner or later, they are very expensive to fix and often the parts have to be factory ordered with perhaps 2 weeks delay. Finally, the pressure often tends to shred the paper and this doesn't flush completely. Kohler toilets have sharp bends in their innards which is a cause of clogging. A Toto Ultramax would be a good choice, but really any Toto will out perform a Kohler.
    For a pressure assist, I've been leaning towards the Kohler Pressure Lite.
    I've installed quite a few of those in homes and restaurants.
    If you want a good bowl for less money, then you might want to look at the Toto Drake.
    I've been selling the round bowl for $239.99 and the ADA bowl for $329.99
    Toto uses a 3" gravity flushvalve.
    The Flushmate system requires a bowl designed to work with it. So you would need a complete tank and bowl setup.
    That's how toilets are sold anyway.
    A pressure assist normally starts at about $290.00
    I have the Kohler Highline with pressure assist for $399.99 in the Seattle area.
    May 2011
    Chicago
    I guess Drake comes in two piece and Ultramax is one, i like the concept of Ultramax, its more clear looking, and easy to clean and maintain, so Ultramax is good.. but again, I am confused between Toto Ultramax I or II and Kohler Pressure lite.
    I see Toto Ultramax II is far expensive as compared to Ultramax I. Any major differences between I and II. I would like to have a 1.4 or 1.6 gpa.
    Personally what would you prefer Kohler Pressure Lite or Toto ultramax I or ultramax II?
    I have the Ultramax II,
    Tall bowl, Sanagloss and double cyclone rinse.
    Between those three, that's my favorite.
    May 2011
    Chicago
    Thanks for the quick reply.. can you please post a link to that toilet? I see multiple models in Ultramax II, but not able to find the one you mentioned.
    May 2011
    Chicago
    The toilet you mentioned above is amazing.
    I might sound nagging and little bit irritating, but here is just one more..
    Is there any toto brand toilet which is sanigloss, one piece, and cost around 250 dollars.
    I wanted to buy two of these.. and did not wanted to invest more than 500 dollars for two of them.
    P.S. If the toilet is double cyclone... it wud be the best. (I know i am asking a lot.. but just trying to push my options).
    You might check to see what the home centers sell.
    It's not going to be a Toto one-piece with softclose seat, but they got stuff.
    IMHO, trying to pick a good pressure-assisted toilet is sort of like asking which model Yugo is the best...there are differences, but I'd not want one in my home.
    May 2011
    Chicago
    I see your point. I had no clue when i was asking for pressure assist toilets. I thought they are the best. Cos i see them in all the good hotels around... specially Marriott and Sheraton.
    Anyways, now that i know about their pro's and con's, i have decided to let them pass, and instead go for Toto. I have been leaning towards TOTO now. I liked the Sanagloss feature on them.
    By the end of the day today or tomorrow morning, i will end up buying an Ultramax II for one of the bathrooms, and a drake or an Ultramax I for the second one. I dont want to be spending more then 500 or max 600 dollars for two. Still looking around.
    May 2011
    Chicago
    As i told you guys, i am here to stay on this forum for a long long time. This place is getting interesting day by day.
    Never in my life i imagined i would be sitting and doing this whole day.
    I have brought enormous gadgets over the years, but it never took me so much pain to go through all the decision making. But a "TOILET"?? wow.. this is facinating.
    I have finally decided to go with Drake II CST454CEFG
    What are the other components i will require to fit this toilet to the bathroom. Plumber will be installing it, hence i would only require the accessories that go with this toilet.
    I know i will need seat cover. what else.. pls guide.
    Any decent plumber will have everything needed to install the toilet: wax ring, flange bolts, supply hose, and it may be a good idea to replace the shutoff valve, too (use a 1/4-turn one, unless there's a good looking one already there).
    Your choice on seats is wide. The Toto Soft-Close seats come in various profiles. Most people like them, some hate them. A generic seat will fit, but may not match the shape as closely, but still eminently usable. Bemis is the only other one I'm aware of that has the soft-close feature. It adds the ability to quickly remove it for cleaning, if that's important to you. I've never used one, but people seem to like them.
    Plumber jimbo's Avatar
    I love my pressure assist ( mansfield ) 19 years. Yes, loud. Splash? not really, but if your house pressure is high, could be. Break up the paper sometimes? Yes. If we use the 'right' paper ( Kirkland or cheaps Scott) if flushes everything in one gulp.
  1. Replies: 8
    Last Post: 08-19-2010, 01:53 PM
  2. Looking for an eco-friendly pressure assist toilet
    By searchingforanewtoilet in forum Toilet Forum discussions
    Last Post: 06-06-2008, 10:44 PM
  3. Pressure Assist Toilet Retrofit???
    By ram5eyd in forum Toilet Forum discussions
    Last Post: 02-19-2008, 09:49 AM
  4. Are All Pressure Assist Toilet Noisy?
    By herbolaryo in forum Toilet Forum discussions
    Last Post: 05-31-2007, 09:52 AM
  5. Could this be the quietest pressure-assist toilet out there?
    By Sepp in forum Toilet Forum discussions
    Last Post: 05-08-2007, 12:23 PM
