Results 1 to 15 of 16
Thread: Delta RP17453 Single spout tub diverter
Hybrid View
    DIY Junior Member acalbear's Avatar
    May 2011
    cali
    Default Delta RP17453 Single spout tub diverter
    I was having an issue with my apartment shower diverter. Its a tub spout diverter. Upon removal I find that the spout is connected to the water supply via a 1" diameter fitting that is about 2" long. The fitting (or water line come from the wall) has about a 1/4 inch threaded section closest to the wall then at the end that is inserted into the diverter has a rubber gasket. This fitting is inserted into a plastic (nylon?) insert within the diverter itself. Upon searching for a replacement i can only find 1/2" diameter to 3/4" diameter kits. I cannot find any diverters with the 1" threaded connector. Any insight on where to find a replacement would be appreciated.
    Thanks from a home tinkerer.
    It sounds like a Delta tub spout with diverter.
    They don't sell those at the big box as replacements, but it's what I like to use.
    If it is a Delta diverter call 1-800-345-DELT and they will replace it.
    May 2011
    cali
    Thanks guys. I will snap a picture of it but there were no markings from what I could see. The spout was poorly made with the inner section which blocks the water when the lever is pulled up was made of plastic not all metal. This portion was what was first bent out of shape allowing the water to flow out and then ultimately broke off when I tried to pry it back in place. I will check again for markings.
    Plumber jimbo's Avatar
    we would like to see a picture, but based on your description.. it IS a DELTA. NO OTHER product even close to that. It is the best diverter spout available, also the easiest to replace. Diverter spouts go bad, and I prefer a diverter on the valve body, but there are very few options anymore for that. Just replace the spout when needed.
    May 2011
    cali
    Default Pictures of water supply line (will snap pictures of Diverter shortly)
Size:  62.6 KBName:  IMG_0128.JPG
Size:  66.4 KBName:  IMG_0130.JPG
  1. How to Replace a Delta Pull Down Diverter Tub Spout.
    By Jerry407 in forum Shower & bathtub Forum & Blog
    Last Post: 08-09-2010, 09:22 AM
  2. Convert from valve diverter to spout diverter?
    By cnr1109 in forum Shower & bathtub Forum & Blog
    Last Post: 05-03-2008, 11:00 AM
  3. Removing old Delta spout / diverter
    By billwil in forum Shower & bathtub Forum & Blog
    Last Post: 09-10-2007, 07:11 PM
  4. any ideas??? DELTA SINGLE KNOB SHOWER-REPLACED WITH PP SINGLE LEVER
    By randy m in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2007, 06:44 AM
  5. Single handle delta clean out?
    By dmetz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2006, 07:14 PM
