Results 1 to 4 of 4
Thread: Copper Supply Line Questions
Hybrid View
    DIY Junior Member maxmitchell's Avatar
    Mar 2007
    Texas
    Default Copper Supply Line Questions
    Thank You!
    The easiest is a riser with preformed end for faucet or ballcock. If you don't use premade risers, you have to have a special beading tool to make a ridge on the the copper so the flat washer and nut will retain the copper and not allow it to pull out of the fitting. The cone washer alone seals well, but is not a tight enough grip tp prevent pull-out.
    Mar 2007
    Texas
    Thank You!
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    I used cp copper tubes with the flat plastic washer but that was brass to brass.Brass nuts to brass fill valve.
  1. Proper Sizing of Copper Supply Line to Cottage
    By chuck b in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-23-2011, 03:23 PM
  2. Installing fridge water line, questions about well water supply
    By thebordella in forum Plumbing Forum Discussion & Blog
    Last Post: 06-27-2010, 04:25 PM
  3. Toto Promenade supply-line placement questions
    By HuntBeer in forum Toilet Forum discussions
    Last Post: 12-05-2009, 11:01 PM
  4. Supply Line Questions.
    By hhcibtpaun in forum Plumbing Forum Discussion & Blog
    Last Post: 03-29-2009, 05:41 AM
  5. Copper water supply line limitations?
    By prashster in forum Plumbing Forum Discussion & Blog
    Last Post: 02-24-2006, 07:15 AM
