Results 1 to 15 of 15
Thread: Drain Cleaning Tips!
    DIY Junior Member sjson's Avatar
    May 2011
    Minnesota
    Default Drain Cleaning Tips!
    You notice the water level in your sink isn't going down. If it is, it's descending at a snail pace. Rather than reaching under the sink for a bottle of Drano, try these tips to ensure a happy sink and ultimately, a happy YOU.
    1. Identify what's causing the clog. If you think the likely verdict is hair, you can simply get a drain stick with barbs in it to retrieve all the hair. If it's something else, it will be extremely useful to identify it to take a different plan of attack.
    2. Stock up on a few simple tools. Purchase the aforementioned drain stick, barbed and smooth. A small wet/dry vacuum is nice to have in the kitchen closet and of course the plunger.
    3. Try to use natural ingredients-based solutions rather than harsh chemical products. A strong vinegar-lemon solution can do the trick for some basic clogs that have things stuck to the side.
    4. Take apart the pipes and clean them out with a toothbrush or some sort of scrubbing pad. WARNING: Make sure you know what you're doing before dismantling the plumbing.
    5. The best thing you can do to clean your drains is by preventing the clogs from the beginning. You can run a natural solution down the drain on a bi-weekly basis. You can purchase a strainer to prevent hair from entering the drain.
    If you have any other suggestions or tips to add please chime in!
    Banned kzhen8's Avatar
    Sep 2011
    new york
    Thanks for the tips! Don't believe in using Drano either or anything that is not natural.
    and when NONE of those "tricks" work, do what you should have in the beginning and call the plumber. FEW stoppages are close enough to eliminate with a "stick", and ANY chemical, natural or not, is ONLY going to make the smallest opening it needs to flow down the sewer.
    In the Trades dave36's Avatar
    Apr 2012
    Philadelphia
    Get a simple manual drain snake, just in case something really gets clogged and a natural solution will not clear it out. It is simple to use and will remove the blockage.
    Dec 2009
    northfork, california
    A garden hose with a tee shirt held tight around any pipe will open just about anything - or jet it into a long drain pipe.
    Quote Originally Posted by ballvalve View Post
    And if the tee tee shirt N hose don't cut through the 4 Ft. root Mass, I use My 3/4 H.P. Maxi Rooter with a newly sharpened Root Saw !
    Plumber AssTyme's Avatar
    May 2010
    Wisconsin
    LMAO !!!
    You very funny !!!!!
    Quote Originally Posted by AssTyme View Post
    LMAO !!!
    Thanks Brother
    Wow cut through 9' of roots with an old sock and garden hose , yesterday. Does R.R. KNOW THIS NEW TECH.
    May 2010
    Wisconsin
    Quote Originally Posted by Boston1 View Post
    Top secret !!!!!!!!!
    DIY Junior Member Natineah's Avatar
    Sep 2012
    Pour a brine solution (or very strong salt water) down any sink to eliminate odors. It is good for kitchen sinks because it keeps grease from building up in the drains after cleaning dishes from dinner. This is a great little trick for preventing clogged drains from happening in the first place, which can definitely save you a nice bundle of cash.
    Shove a hose and rag into the drain line and turn on the water. Unless the stoppage is very "loose" the water will rise up in the vent pipe and flow out onto the roof. Then when you turn the water off and remove the hose ALL that water will drain out of the pipe into the sink cabinet and onto the floor.
    DIY Junior Member Brokersdad's Avatar
    Nov 2011
    canada
    In the past I had my kitchen and dishwasher drain plug that it would no longer drain (didn't give me much warning either) . I cut the very end off my drain pipe, inserted an air hose running from my air compressor and started blowing air through it...(make sure any sinks in this line have the drain plugs in and tight). You can actually hear the stuff in the drain moving, if it's being stubborn, run some water then hit it again ..repeat if necessary. It will free it up ,and blow the blockage out. Then I run hot water down it for 5-10 minutes to make sure it takes it all to the exit point. Remember, drain plugs in..it aint pretty if you don't..I found out the hard wayLOL
    DIY Junior Member Luckett83's Avatar
    Oct 2012
    Virginia
    I get clogs all the time in my bathroom sink and tub. I typically use some sort of chemical remover, but it's great to hear about some of the more friendlier methods. I also think taking proactive steps to lessen clogs is crucial, but when multiple people are using it, that can be easier said than done. Thanks for the tips!
    May 2010
    Wisconsin
    Yes thanX for all the great tips I'm going to give them a shot on my upcoming service calls
  1. Looking for tips on using a powered drain snake.
    By itguy in forum Drain Cleaning
    Last Post: 04-17-2012, 01:20 PM
  2. Looking for tips on using a powered drain snake.
    By itguy in forum Plumbing Forum Discussion & Blog
    Last Post: 03-27-2010, 10:45 AM
  3. Drain cleaning
    By psjr56 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-12-2009, 06:29 AM
  4. Cleaning a field drain
    By wishon1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-04-2008, 05:24 PM
  5. Cleaning turbo torch tips?
    By Marlin336 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-17-2008, 06:10 PM
