Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Another Pitless Adapter Question
    DIY Junior Member mortal798's Avatar
    May 2011
    Pinckney, MI
    Default Another Pitless Adapter Question
    Hey everyone,
    I am having well problems. My 1/2 hp 230v pump runs all the time 24/7. It puts out 22psi and 3gpm. The pressure never gets high enough to trip the switch off. I need to pull the pump.
    The pitless adapter in my well is one that I can't find any mention of excpt here.
    Anybody ever see one of these? How do you get it to let go? I am an Auto Tech Instructor, so I can fix just about anything. I have never had to deal with anyting like this, so any help would be HUGE!
    May 2011
    Pinckney, MI
    Default Pitless picture
    Name:  pitless adapter.jpg
    Here is the pic...
    In the trades WellWaterProducts's Avatar
    Feb 2011
    Northwood NH
    It looks like it may be something like: http://www.baker-mfg.com/domestic_ne...s/Bulldog.html
    Chris Kofer
    h2oguy.com
    May 2011
    Pinckney, MI
    Kind of, but there is no pull-cable on it - or even a hole for a pull cable to go. It looks to me like this (which I just found a minute ago):
    http://www.merrillmfg.com/product/02...-Kit/parts.htm
    May 2011
    Pinckney, MI
    I am starting to think that I just need to pry up on the tab near the pin. As you can see from the pic, there is no safety cable attached to the pump. Is that a good sign - like the pump isn't very far down? Or is it a bad sign - like the company that installed it was too cheap to attach a rope to the pump?
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by WellWaterProducts View Post
    Is "something like", the same - only different? :P
    My pitless has a steel release cable that moves a cam. I'm not seeing any release cable in the photo. It looks like a hinge pin on a cam but how is the cam rolled?
    May 2011
    Pinckney, MI
    Oh, this is a 5" well, the pitless is exactly 4' below grade, and the water is 18' below grade. I have no idea how deep the well is or how deep the pump is set, but I am hoping not too deep...
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by mortal798 View Post
    Ja, I was wondering if the release didn't go down the inside of the pull pipe like in the link you posted.
    May 2011
    Pinckney, MI
    Man, I thought for sure somebody was going to bust out with all of the information by now!
    Should I just make a hook and go for it?
    Feb 2011
    Northwood NH
    It has been over 15 years since I removed one of those. I think that the rod has a lot to do with releasing it. Post a picture of the top of your well.
    Chris Kofer
    h2oguy.com
    May 2011
    Pinckney, MI
    That would be about right, this well was put in with the house in 1994.
    May 2011
    Pinckney, MI
    Default Top of well
    Here is the top...Name:  Top of well_1.jpg
    Feb 2011
    Northwood NH
    Look at the link for the product and it takes you to installation instructions. From what I remember, you need to be very careful when removing it to not lose the oring.
    Chris Kofer
    h2oguy.com
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    I believe that is one of those kinds of pitless adapters that you need a tool to unhook. I believe you need a rod with washer welded to the bottom. The washer works like turning a screw with a coin. You reach down in that 1" pipe with the rod, stick the washer into a groove, and turn it to the left to loosen the lock. At least that is my best guess.
    Feb 2011
    Northwood NH
    Installation Instructions
    1. 1. Cut and thread 1" pull pipe. (See chart for length). Assemble support bar, pull
      pipe, and pitless body. Be sure that arrow on support bar and discharge hole on pitless body are in line with each other.
    2. Cut a piece of 1/2" pipe 3" longer than pull pipe and flatten one end to fit stainless steel screw or weld on adjustment tool to one end of 1/2" pipe.
    3. Measure distance from bottom of support bar to center of discharge hub, or use assembly as a measuring stick.
    4. Drill hole in casing, the same measured distance as above:
      4" casing - 1-1/4" hole or smaller
      5" casing - 1-1/4" hole or smaller
      6" casing - 1-1/4" hole or smaller
      NOTE: For 2" MCK model - 2" hole or smaller
    5. Notch or mark top of casing directly above discharge hole.
    6. Clamp discharge hub around casing to assure watertight seal around discharge hole.
    7. Attach pump and drop pipe to pitless body, apply Anti-Seize/Gasket Lube to
      O-ring, and lower into casing.
    8. Line up mark on support bar with notch cut in casing.
    9. Turn stainless steel screw clockwise until O-ring seals on inner wall of casing.
    10. Complete installation by installing watertight or ventilated cap on top of well casing depending on state well code.
    Chris Kofer
    h2oguy.com
  1. pitless adapter question
    By heatherw in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-07-2010, 12:46 PM
  2. Installing a pitless adapter
    By jj92310 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-15-2009, 05:39 AM
  3. pitless adapter question
    By cobra in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-22-2008, 07:13 PM
  4. pitless adapter
    By lardlad in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-24-2008, 06:09 AM
  5. pitless adapter
    By rich07746 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-27-2006, 07:22 PM
