Here is the pic...
Hey everyone,
I am having well problems. My 1/2 hp 230v pump runs all the time 24/7. It puts out 22psi and 3gpm. The pressure never gets high enough to trip the switch off. I need to pull the pump.
The pitless adapter in my well is one that I can't find any mention of excpt here.
Anybody ever see one of these? How do you get it to let go? I am an Auto Tech Instructor, so I can fix just about anything. I have never had to deal with anyting like this, so any help would be HUGE!
Here is the pic...
It looks like it may be something like: http://www.baker-mfg.com/domestic_ne...s/Bulldog.html
Kind of, but there is no pull-cable on it - or even a hole for a pull cable to go. It looks to me like this (which I just found a minute ago):
http://www.merrillmfg.com/product/02...-Kit/parts.htm
I am starting to think that I just need to pry up on the tab near the pin. As you can see from the pic, there is no safety cable attached to the pump. Is that a good sign - like the pump isn't very far down? Or is it a bad sign - like the company that installed it was too cheap to attach a rope to the pump?
Oh, this is a 5" well, the pitless is exactly 4' below grade, and the water is 18' below grade. I have no idea how deep the well is or how deep the pump is set, but I am hoping not too deep...
Man, I thought for sure somebody was going to bust out with all of the information by now!
Should I just make a hook and go for it?![]()
It has been over 15 years since I removed one of those. I think that the rod has a lot to do with releasing it. Post a picture of the top of your well.
That would be about right, this well was put in with the house in 1994.
Look at the link for the product and it takes you to installation instructions. From what I remember, you need to be very careful when removing it to not lose the oring.
I believe that is one of those kinds of pitless adapters that you need a tool to unhook. I believe you need a rod with washer welded to the bottom. The washer works like turning a screw with a coin. You reach down in that 1" pipe with the rod, stick the washer into a groove, and turn it to the left to loosen the lock. At least that is my best guess.
Installation Instructions
- 1. Cut and thread 1" pull pipe. (See chart for length). Assemble support bar, pull
pipe, and pitless body. Be sure that arrow on support bar and discharge hole on pitless body are in line with each other.- Cut a piece of 1/2" pipe 3" longer than pull pipe and flatten one end to fit stainless steel screw or weld on adjustment tool to one end of 1/2" pipe.
- Measure distance from bottom of support bar to center of discharge hub, or use assembly as a measuring stick.
- Drill hole in casing, the same measured distance as above:
4" casing - 1-1/4" hole or smaller
5" casing - 1-1/4" hole or smaller
6" casing - 1-1/4" hole or smaller
NOTE: For 2" MCK model - 2" hole or smaller- Notch or mark top of casing directly above discharge hole.
- Clamp discharge hub around casing to assure watertight seal around discharge hole.
- Attach pump and drop pipe to pitless body, apply Anti-Seize/Gasket Lube to
O-ring, and lower into casing.- Line up mark on support bar with notch cut in casing.
- Turn stainless steel screw clockwise until O-ring seals on inner wall of casing.
- Complete installation by installing watertight or ventilated cap on top of well casing depending on state well code.
