Results 1 to 4 of 4
Thread: Bad water pressure gauge
    DIY Junior Member mikeandteri's Avatar
    Sep 2008
    Maryland
    Default Bad water pressure gauge
    Hi, Water pressure gauge reads zero but pump seems to run alright. No obvious loss of pressure as pump does not kick on more than usual. Can pressure gauges go bad with no harm to the system? Will get it replaced but did not want to make an emergency drive to Home Depot in snow.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    The gauge is only for you to see. It has nothing to do with the workings of the system. My guess is that it doesn't read zero but rather has wrapped all the way around from freezing, and looks like zero again. The needle is probably on the other side of the stop post.
    Sep 2008
    Maryland
    Thank you for the reply. No it reads just off zero on the correct side. Could it have gone bad or clogged with some sediment? We do have sediment in our well.
    Jan 2012
    California
    Pressure gauges do wear out. Check out this video from WIKA, one of the best pressure gauge manufacturers. A little more expensive than most, but worth it!
  1. Low water pressure, pressure tank gauge
    By epeloke in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2012, 07:03 PM
  2. Water hammer bouncing pressure gauge needle AFTER pressure tank fills
    By hawkhunter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2012, 10:35 AM
  3. Is my pressure gauge shot?? low water pressure.
    By help4steveo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-15-2010, 04:33 AM
  4. Water Pressure Gauge
    By steveg91 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2007, 08:08 AM
  5. water in pressure gauge
    By baylander in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-01-2006, 04:40 AM
