Results 1 to 12 of 12
Thread: WC venting alternatives
Hybrid View
    DIY Junior Member Earl001's Avatar
    Aug 2007
    El Segundo, CA
    Default WC venting alternatives
    Tried a more difficult post in the general forum with no luck (http://www.terrylove.com/forums/show...for-sunken-tub). So I’ll try here with the second part of my venting question.
    Which of the following venting layouts for a WC is permitted/recommended? Plan B requires a much longer horizontal vent so is less preferable from an installation point of view.
    Plan A
    ……………………………f…………v…………………..
    ……………………………b………..ddddz……………
    ……………………………b………..……….z…………..
    ……………………………bbhhhhhhhhyyhhhhhhhh
    Or
    Plan B
    ………………………………….….v…………………
    ……………………………f……….ddddddddddv
    ……………………………b………..………………..v
    ……………………………bbhhhhhhhhhhhhcc
    ………………………………………………………….c
    Where
    f = WC flange
    b = 3" 90 deg vertical to horizontal
    h = 3" horizontal run sloped at 1/4 in/ft
    d = 2" horizontal (dry) vent sloped at 1/4 in/ft
    v = 2" vent vertical to roof
    c = 3" medium 90 deg horizontal to vertical with 2”
    y/z = 3"x3" Y fitting with 2" exit rotated ~60 deg rolled so that it is above the horizontal centerline of the drain connected to 2” 45 deg bend leading to a 2" horizontal dry vent
    Earl,
    In California, they use the UPC code,
    Here is a nice link to Bert Polk's plumbing tips
    Bert is a plumbing inspector for UPC.
    Aug 2007
    El Segundo, CA
    Terry,
    Thank you. The tips are quite informative! However, all his photos show the vent traveling vertical or what looks like 45 deg then vertical. He does not say anything about a flat vent. Perhaps the diagram below may help explain my dilemma. Due to space limitations I must run the 3" line along the joist line to the girder. Doing so makes a vertical vent impossible. Do you think this layout will cause problems? If the Y is a problem (it's not vertical but rotated 45 deg from horizontal), I think I could fit a combination long Y to the 2" flat vent instead. In this case I'd plan to rotate it from horizontal so it is as vertical as possible.
    We are allowed to do what your last post shows.
    Wye turned above the flow line of the pipe, using waste fittings below the flood level of the fixture.
    Aug 2007
    El Segundo, CA
    Great. Thank you so much Terry.
    Just so I can learn a little from this, it would be nice to know what "using waste fittings below the flood level of the fixture" means. Since I'd think the flood line for a toilet is at the rim wouldn't all fittings be below that? Or does this mean that the vent line must be dry (i.e not be a 'waste fitting' by being turned above the flow line of the pipe) since that does go above the rim.
    earl
    The flood lever of a toilet is the bowl.
    Most plumbers revent at 42" which is 6" above the flood level of the highest fixture, the kitchen sink.
  1. P-trap Alternatives?
    By turnerAK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2014, 06:56 AM
  2. Sewer sleeve alternatives
    By ddutchover in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-30-2010, 07:36 PM
  3. Kinetico alternatives?
    By Mastiff in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-07-2010, 10:47 PM
  4. Downdraft cooktop-alternatives to outside venting??
    By Eagle45 in forum HVAC Heating & Cooling
    Last Post: 01-26-2009, 10:28 AM
  5. sump pump alternatives
    By jcress in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-01-2006, 08:38 AM
